Camshaft Identification
20 replies to this topic
#1 oltonlad
oltonlad
  • 2,401 posts
Posted 19 June 2012 - 06:47 PM
hi, i need to identify a camshaft, it is a pin drive and has 1 raised ring between lobes 3 & 4, i have searched on AC dodds webpage but i cant find a picture of a cam with those markings.
any ideas guys?
cheers.
#2 03jkirk
03jkirk
  • 465 posts
Posted 19 June 2012 - 06:54 PM
this is best place i have found for cam IDs
http://www.mlmotorsp...topic,11.0.html
#3 coopdog
coopdog
  • 4,506 posts
Posted 19 June 2012 - 07:16 PM
+1
#4 oltonlad
oltonlad
  • 2,401 posts
i've already looked on there.......its not listed.
#5 oltonlad
oltonlad
  • 2,401 posts
Posted 19 June 2012 - 08:39 PM
wheres bmc or cooperman.......:-)
#6 Cooperman
  • 23,276 posts
Posted 19 June 2012 - 08:41 PM
It might be a 510 as fitted to the Mk.1 Cooper 'S'. That had a single ring, pin-drive oil pump, 1/2" wide lobes and no fuel pump lobe. A very nice cam if that's what it is. Recommended timing is 110 deg ATDC.
Edited by Cooperman, 19 June 2012 - 08:42 PM.
#7 oltonlad
oltonlad
  • 2,401 posts
Posted 19 June 2012 - 08:43 PM
it has a fuel pump lobe, i cant find how to ID it anywhere and its doing my head in now.......:-(
Edited by oltonlad, 19 June 2012 - 08:43 PM.
#8 oltonlad
oltonlad
  • 2,401 posts
Posted 19 June 2012 - 09:33 PM
i've been looking around the internet for ages and all i can find is this............
2A948 cam (997 Cooper) which also has one narrow ring and is pin drive, but it is narrow lobe and has a fuel pump lobe.
what do you guys reckon?
#9 oltonlad
oltonlad
  • 2,401 posts
Posted 19 June 2012 - 10:16 PM
right, i've found the answer, the only pin drive cams with the 1 ring identification mark is the AEG510 cooper 's' cam (no fuel pump lobe) or the 88G229/2A948/12A122 997 cooper camshaft (there were 3 part numbers for that cam)
therefore the cam that is in my old engine is a 997 cooper cam as it has the 1 ring ID mark and a fuel pump lobe........:-)
#10 Cooperman
  • 23,276 posts
Posted 19 June 2012 - 10:37 PM
I wonder why a 997 Cooper cam would have a fuel pump lobe. They all had Lucas electric pumps. Maybe they used a blank cam from an engine with a mech pump.
#11 oltonlad
oltonlad
  • 2,401 posts
Posted 20 June 2012 - 06:37 PM
not sure but someone said that the 997 cam was a good one to use for the 1098 engine, that ties in with the 12G295 head and 20 thou overbore that the engine had when we got the car.
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 07 December 2014 - 06:14 PM
The lobe on the 2A948 cam is because it was THE 'rally' cam for the Spridget - back in the day.  But virtually all cams have the fuel pump lobe - until relatively recently.
Edited by bmcecosse, 07 December 2014 - 06:26 PM.
#13 Spider
  • 14,838 posts
Posted 07 December 2014 - 06:21 PM
The same cam as fitted to the 997 was also fitted to the 1098's that had a mechanical pump, though they did come along later.  I'll look in my charts this arvo and see if I can ID the cam.
#14 bmcecosse
bmcecosse
  • 9,699 posts
Posted 07 December 2014 - 06:26 PM
Never fitted to 1098 engine  - certainly not in Production.   Yes - fitted to 997.  Mystery is  - why did they not continue it in the 998 Cooper ??
That cam ID site doesn't seem to work now - anyone point to one that DOES work ??
Edited by bmcecosse, 07 December 2014 - 06:27 PM.
#15 Spider
  • 14,838 posts
Posted 08 December 2014 - 07:40 AM
Coming back to the OP's question, are the lobes 3/8" or 1/2"?
Yes, I stand corrected on that. They didn't continue them in to the 998 Coopers as they were fitted with a better Cylinder Head. The 998 Cooper Cam was also fitted to the 1098 (at least the ones we had here!).
