Rust Inside Petrol Tank (Pic)
Posted 17 June 2012 - 03:29 PM
Posted 17 June 2012 - 03:45 PM
Posted 17 June 2012 - 04:00 PM
Posted 17 June 2012 - 05:49 PM
Posted 17 June 2012 - 06:25 PM
Posted 17 June 2012 - 06:27 PM
Posted 17 June 2012 - 08:31 PM
Posted 17 June 2012 - 09:03 PM
Posted 17 June 2012 - 09:07 PM
Not great, but will probably end dirt cheap http://www.ebay.co.u...4#ht_500wt_1129
Much better, and still quite reasonable http://www.ebay.co.u...e#ht_500wt_1129
Edited by minimissionary, 17 June 2012 - 09:07 PM.
Posted 18 June 2012 - 01:16 AM
Remember that the fuel pickup in the Mini tank is not resting on the bottom. The pickup also has a coarse plastic mesh screen over it to keep big pieces of debris out. As such, only the smaller bits of trash will have reached the carb. However, you may find a lot of that small debris when you check the float bowl. When you are going through the system (hopefully with a new good used tank) consider fitting a COARSE filter between the tank and fuel pump and a FINE filter on the discharge side of the pump before the carb(s). The coarse filter will catch any big pieces that make it through the tank mesh. That protects the pump. The fine filter will protect the carb(s). You do not want a fine filter before the pump because fuel pumps "push" better than they "pull". You do not want to experienced a fuel system failure by putting a fine filter on the pump's suction side.
Posted 18 June 2012 - 11:35 AM
I think I'd just get a new tank. For the money, I'd rather have the peace of mind.
watching these as we speak. My only concern with buying a second-hand one is not knowing if it'll be any better than mine!
Doug, cheers, I'll get the filters fitted during the rebuild
Edited by CBJ805T, 18 June 2012 - 11:36 AM.
Posted 18 June 2012 - 12:11 PM
I have cleaned and sealed tanks. It can be done at home. However, I chose to do that because Mini tanks are few and far between over here. Given your options I would seriously consider taking the advice above and get a good used tank instead of trying to recondition that one.
Sorry for the hijack, very iteresting info i have a coarse filter between the tank and pump, but after reading your info want a fine filter for after the pump - is this any good:
http://www.ebay.co.u...=item27b481f913
If not do you have a link to a better one?
Edited by richw911, 18 June 2012 - 12:12 PM.
Posted 18 June 2012 - 12:27 PM
On the discharge side of the pump (just before the carbs) I use a disposable, plastic filter typical of what was once common on air cooled VWs. I like being able to look into the filter to see how much debris is there and how dirty the element is. The link below is for the VW type filter that I use. I buy them 5 at a time off eBay as they are much cheaper that way than buying them from the local parts store. I use them on all my British cars.
http://www.vollks.co...ages/P/9949.jpg
Posted 18 June 2012 - 10:09 PM
