How to get that shine after painting
85 replies to this topic
#1 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 10 March 2006 - 08:48 AM
You can see the full details in the projects section, but here is the flatting and polishing guide
Cheers.
clicky
Well at the weekend i decided it was time to finish the estate of as the paint had long enough to cure.
Sorry about the poor pics, left the camera at home, so used the phone camera,
Although the finish was good, it could be better
So first thing to do was to clean down the car
and then using wet and dry 1500, and soapy water the flatting process began
I did this in a way that anyone can follow, no special tools etc.
So the first step was to wet the bonnet, for this I use a spray bottle with soapy water.
The paint is rubbed with the 1500 until all the little shiny bits of paint including dimples etc have turned dull.
I tend to use a Hydra blade, but here a wiper blade was used to clean away the water so you can look closely at the paint for shiny bits. If you look closely at the pic below you can see a couple little bits, this is fine but the smoother your paint the better your shine.
The effect you are looking for is this pic below
But keep looking at the paint otherwise you can rub through it.
Work your way round the car flatting all the paint down in the same method
Then after using G3 (will come back to this) and the buffer this was the effect
It has not been polished at this point...!
It does take alot of effort so work on one panel at a time
The polishing after the flatting procedure.
You need a buffer (Not angle Grinder) you are looking for a variable speed buffer that goes from about 1000 - 3000 rpm ish
Use a G3 compound and loads of water and polish the panel until you see it shine.
Do not let the panel go dry, keep putting water on it or it will scorch the paint.
This should leave the following effect
You can see better in this pic what it looks like after a quick wipe
and again
and after a quick hand polish
Nice and shiny
and another
and look at the reflection of the tail light on the door :w00t: all worth it
#2 Amy
Amy
  • 878 posts
Posted 10 March 2006 - 09:42 AM
I've got that job ahead of me in a couple of weeks.... After restoring Momo our mini van I swore never to do another car again, it's a lot of hard work.
But here we are again, spending even longer on the woody estate!
How long did you leave your paint to cure by the way? I was thinking a few weeks would be plenty this time.......
It's worth all the effort when people say how lovely and shiney your mini is :w00t:
Looks really good by the way Shaz! :ph34r:
#3 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 10 March 2006 - 11:05 AM
Hi Amy
I left it for about 2 weeks, basically had to do a couple little bits for the MOT so did them first.
It was baked in the oven but the longer you leave it the better it is.
Loving the look of your project too....!! :w00t:
Fantastic..!
#4 Amy
Amy
  • 878 posts
Posted 10 March 2006 - 11:22 AM
Ours is cellulose so it didn't need baking!
Thanks.... :ph34r: We're really getting on with Toad now, but there's sooo much to get done before the Riv Run (our target finish date).
To be honest, I'm glad I'm past the stage of funny coloured bogeys. At least the cutting back stage doesn't create dry dust!.... hehehehe :w00t:
#5 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 10 March 2006 - 12:21 PM
hahahhahahahah :D , you cant beat multi coloured bogeys...
#6 jack_marshall
jack_marshall
  • 2,540 posts
Posted 24 March 2006 - 05:02 PM
Very good guide.
I dont think you mentioned about keeping the wet and dry constantly soaking wet. If you keep rubbing and rubbing and it suddenly feels "scratchy" as your rubbing, chances are your going to make a nice mess of your new paint!
Keep the wet and dry constantly soaked, using plenty of soap to make it glide easier.
Just thought I'd sa :rolleyes:
#7 Super Mario
Super Mario
  • 44 posts
Posted 30 March 2006 - 04:36 PM
Does this work over bonnet stripes and other decals? Or will they peal off?
Is there an alternative to using an electric buffer?
Thanks.
#8 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 02 April 2006 - 11:07 AM
Thanks.
It depends on how the bonnet stripes are done, if they are vinyl adhesive type then , no, you just polish round them.
If they are painted on and laquered in so that the panel is smooth then yes it will work.
As an alternative to the elec buffer there is good old elbow grease, but it will be a heck of a hard job through
#9 Amy
Amy
  • 878 posts
Posted 02 April 2006 - 11:27 AM
Tell me about it.... We've just ordered a pro polisher so I can get on with the car.... The last mini I cut back didn't have as much paint on it, which meant less orange peel, so I did that by hand.
Toad has had sooo much paint that it's killing me trying to cut it back by hand. The main job using the 1500 paper is just as hard, but the polisher will definitely make my life a little easier when it arrives!!
#10 minipixie
minipixie
  • 1,646 posts
  • Local Club: Lincoln TMF and Notts TMF
Posted 02 April 2006 - 11:33 AM
can this only be done on paint that has just been applied (and when i say just i mean like a couple of weeks ago, like u said in ur post) or can it be done on any paint?
#11 Amy
Amy
  • 878 posts
Posted 03 April 2006 - 08:08 AM
Pixie, as far as I know paint can be cut back at any time....
If it's been there for many years it will be much harder, but I remember an old pro telling me once that Celly doesn't properly cure for 50 years!
I would be more careful using the above technique if you have no idea how much paint is on the car... You'd be better trying something gentler like t-cut first. You'll be amazed what a difference a mild compound and a polish will make to a car!
#12 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 03 April 2006 - 10:04 AM
As Amy says, you can do this on any age car, but the only thing you need to be careful about it the
paint thickness, ie sanding through the paint.
Although you generally find if it is a proper job using a spray gun you shoud have enough paint on there.
Is it scratches you are trying to polish out or just get a better shine?
Because you can use the G3 paste to polish and remove small scratches etc too.
Here are pics of another one that needed the scratches polished out, if you look at the reflections you
see how the manufacturers paint is rough, this car is 7 years old
Have a look below at the before pics and After pics
Can you spot the difference ??
This was done with p2000 wet and dry, loads of water and both G3 and G10 polishing compound, then polished
with Duraglaze polish
#13 minipixie
minipixie
  • 1,646 posts
Posted 03 April 2006 - 10:25 AM
whoa the reflection on the second picture is just crazy clear!!!!
just want to get a better shine! it was only resprayed in october
#14 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 03 April 2006 - 02:07 PM
You could use G3, it will smooth the paint and increase the shine.
You can wet flat it with P2000 then G3 it.
Can you give close up photos of the door with a reflection in it (like I have done above)
this will give an idea of the paint on the door and what to do with regards to flatting and polishing.
#15 pikey7
pikey7
  • 3,824 posts
Posted 03 April 2006 - 02:09 PM
This technique also works well on oxodized paint (e.g. when red paint goes pink!) and is a damned sight cheaper than a new paint job!
Nice write up Shaz!
