Mercedes A Class Engine Conversion ?
6 replies to this topic
#1 stretch tech
stretch tech
  • 1,363 posts
  • Local Club: A5 & Mini Mainiacs
Posted 12 June 2012 - 08:25 PM
hi all, i was just looking around for possible engine conversions and i thought about the smart cars engine but after reading a topic on here about it, i soon found it isn't worth it because of the electronic gear change. i found that the largest engine in a smart car is in the forfour which is a cut down 3 cylinder version of the 4 cylinder engine in the A class. this is available in 1.4L 1.6L 1.7L 1.9L and 2.1L capacities and in natural aspiration or turbo charged versions with a 5 or 6 speed manual gear box. so i was thinking, is this a viable engine conversion ? i think it is mounted horizontally in the A class so would converting it to running vertically be a big issue or not ?
just thinking about future engine projects :proud:
Rhys
Edited by stretch tech, 12 June 2012 - 08:25 PM.
#2 Broomer
Broomer
  • 1,771 posts
Posted 12 June 2012 - 08:28 PM
A vertically mounted engine?
#3 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 12 June 2012 - 08:33 PM
hi mate i have a mercedes a140 the engines are quite nippy they have a similar engine layout as a motorcycle as there mounted under the foot well with only the air box under the bonnet
#4 SA MINI
SA MINI
  • 1,001 posts
Posted 12 June 2012 - 08:37 PM
ill be honest i think the oil will not flow properly if it was vertical also it would be too long & there would be issues with exhaust manifold & drive-shaft position
#5 stretch tech
stretch tech
  • 1,363 posts
Posted 12 June 2012 - 08:49 PM
SA MINI - cheers mate, i've never worked on an A class before, i thought they were rear engined >_< thinking about it, it is quite a long engine, that would require one ma-hooosive bonnet bulge if it was mounted vertically :lol: lol. i gather that's the 1.4L engine, what sort of power and torque do you get out of it ?
Rhys
Edited by stretch tech, 12 June 2012 - 08:49 PM.
#6 SA MINI
SA MINI
  • 1,001 posts
Posted 12 June 2012 - 09:28 PM
roughly 82-83 bhp very nippy for a 1400 8valve mpg is over 40 on motorway too.
i think the engine in the pic is the 1.6 petrol
all the engines are almost identical 1.4 petrol - 1.6 (bored out 1.4) 170 diesel - 190 diesel. 220 petrol turbo.
the engine was designed to shift under the car instead of on your lap when in a crash.
i don't think there's any chance of getting it in the front of a mini anyway the drive shafts actually come out of the gear box at the front just in the right corner of the picture.
#7 charie t
charie t
  • 3,153 posts
Posted 12 June 2012 - 09:52 PM
get yourself a tape measure, andf get along to scrap yard. The only way its going to get done is to measure or try it
