Posted 15 June 2012 - 08:46 PM
thinking about it.. a smart car has 3 cylinders, a mini engine has 3 exhaust ports. yes the turbo is built into the manifold but you could make up a 3 piece exhaust manifold from the head, taking it down 90 degrees from the head to attach to each port on the turbo, maybe a custom inlet manifold to tilt the carb to give a little extra room, its doable i reckon, thou i know nothing about the performance of the turbo and i dont know the dimensions for clearance.. but the fact its built into the manifold shouldn't be a problem..you might even be able to just make up a adaptor plate and bolt the turbo straight onto the head anyway :L
