Now, the problem is here... some say that metro hubs on a mini make`s alot of difference in road holding since they have different geometry!! but is it a big difference or not? i took some pics which will show some difference in distance between ball-joints from drum type to disk, which will result more distance between lower and upper arm, and also the angle of the lower ball joint. Camber angle will be affected to more Positive? which mini is already positive or to Negative?
I know about the problem of bump steer, but i think this will apply when one install a 13" wheels with deep dish which result more leverage for swivel hub. Also i found that the metro ball joint match with the mini wishbones.
So my question is!! Am I doing a mistake if i install all this on a metro hub?
