Complete Floor Pan Replacement?
#16
Posted 06 June 2012 - 01:47 PM
If only the inner and outer sills are shot then why change the complete floor. If your welding skills are good enough then doing either a half floor or the complete inner sill replacement will be fine. Plus like Jagman said the shell has to be properly braced and a fistful of measurements taken to ensure nothing goes out of kilter.
We have seen one picture of a rusty sill and not the whole car so to make a proper assessment all of the damage needs to be seen.
#17
Posted 06 June 2012 - 01:51 PM
Do the companion bins have to come out to do the sills?
Might plug my jacking point up aswell, I always use the thicker bits on the subbies for jacking.
#18
Posted 06 June 2012 - 01:54 PM
Paddys new jacking point
Flitch damage
#19
Posted 06 June 2012 - 02:02 PM
If I were to do it to mine, I don't have a spot welder- would plug welds do in place of spot welds?
#20
Posted 06 June 2012 - 02:08 PM
Inner sill repair section
And yes plug welds will be fine.
#21
Posted 06 June 2012 - 02:26 PM
Upwards and onwards,went to refit the l/h inner sill stiffener but found that Mr Rust had perforated it in several places, very inconsiderate so 15 mins later fabricated a new slightly shorter version
very happy with it so in it went after i had fitted the heel board close out panel
all ground down
Also sorted the 1/2" extension piece for the outer arch needed at the front of it so that will be fitted tomorrow then lashings of paint before i move onto replacing the waist rail and installing the rear quarter panel.
I copied this from Erms thread and it shows the inner sill stiffener.
#22
Posted 06 June 2012 - 02:39 PM
I've just gone out and took some pictures of the seam and oversills etc, I'll get them up here in abit- the seam looks abit bubbly on one side
#23
Posted 06 June 2012 - 03:20 PM
front of the passenger side (note, theres a hole that leaks water out when you rock the car
rear of the passenger side:
passenger side seam:
More of the passenger side seam:
Another shot of the front of the passenger side:
Drivers side front:
drivers side seam:
drivers side rear:
And finally the welding underneath:
pretty much the same all the way accross.
Theres water in the big hole I pictured earlier, it comes and goes dependant upon weather, and theres a crack/hole a few mm's wide and about 100mm long midway up on the passenger side door step. Both of these leak water into the footwell.
#24
Posted 06 June 2012 - 06:18 PM
The bottom of the quarter panel will need to be replaced as well as the A panel. Door skins will need doing as well.
With the A panel gone i would whip that off as that will allow you to work on the flitch panel if required. If you decide to replace the lower sections of the quarter panels then this will give you good access to the inner sill behind the companion box and the inner sill stiffener.
None of it is good news but none of it is the end of the world. Its just going to take time to sort it all out.
#25
Posted 06 June 2012 - 08:25 PM
Time for a crash course in welding and to borrow an angle grinder I think.
#26
Posted 06 June 2012 - 09:17 PM
Thats about a grands worth of work easily!!
#27
Posted 06 June 2012 - 09:33 PM
#28
Posted 06 June 2012 - 10:03 PM
Starter kit on ebay for £150 with everything I need bar a decent helmet, think I'll be getting that.
If my MOT is due august 25th, what would you guys advise? I'm yet to drive it/insure it, and I'm itching to do so but I'm reluctant to pay insurance if it'll be pulled off the road within a couple of months. Should i wack a sorn on it once I'm ready and get welding?
Edited by Lee_bash, 06 June 2012 - 10:09 PM.
#29
Posted 06 June 2012 - 10:06 PM
Post up a link of what you're after before you buy.
