Complete Floor Pan Replacement?
Posted 05 June 2012 - 10:19 PM
Posted 06 June 2012 - 06:05 AM
A full floor does a neater job, involving less welding (no full-length seams), but really needs to be done on a jig, as almost all rigidity is lost while the floor is out. Edge panels can be done, carefully, one at a time without a jig.
You can get floor edge sections with the outer sill already attached, but I can't see how they can be of much use, as they must limit access to properly weld the vital heelboard/subframe mount stiffners. By the way, expect to need at least heelboard ends, and some work in the rear bin area.
Posted 06 June 2012 - 07:16 AM
Edited by jagman.2003, 06 June 2012 - 07:16 AM.
Posted 06 June 2012 - 07:35 AM
I guessed a whole floor would be exxecsive- but wasnt sure how much work it would be compared to doing 2 new sills. I think, if it wasn't much more then I'd be tempted to go for that, purely because if done right itd last longer I'm guessing?
Anywho, think I need to start taking it to get quotes done for the work required... there is a hole on the inner sill I know of so they'll need doing.
Posted 06 June 2012 - 08:35 AM
If you fancy a ride out to Telford I'll take a look with you and we can see how bad it is.
Posted 06 June 2012 - 08:47 AM
Cheers for the offer mate- Telford could be abit far I think, seeing as I'm not insured to drive it just now i'd have to get someone else to drive it up, but thanks!
Edited by Lee_bash, 06 June 2012 - 08:53 AM.
Posted 06 June 2012 - 08:51 AM
Thats the hole on the inner sill, the worse ive found on their so far. Id say its about an inch and half wide, about 4-6'' long, if that.
I chipped all the sound proofing around it away to leave the hole, and metal around it so I could see how big it was...
Posted 06 June 2012 - 10:01 AM
If you had a bare shell, I would say to chop it all out... Because somebody else is doing the work, it probably won't work out much/any more expensive, if you add all the labour costs (including tidying the repaining floor).
... HOWEVER- because it's not a bare shell, it would be hard to get at certain areas and it would also be very hard to get suitable bracing in the shell to keep it from flexing.
What I would suggest, is that you buy the floor panels with outer sills attached from m-machine. They do the full widths as well as just the first few inches of the floor if that's all you need
Posted 06 June 2012 - 12:17 PM
Posted 06 June 2012 - 12:33 PM
When you say half floorpan, do you mean full length, but half width, with outer sills attached?- if so, I would say it'd take about 4 hours each side, but you can add a lot to that depending on how much you have to repair in the surrounding areas and include things like removing pipe-work and interior.. Then you need to add the painting and undersealing too.
Posted 06 June 2012 - 12:37 PM
Edited by Lee_bash, 06 June 2012 - 12:38 PM.
Posted 06 June 2012 - 01:12 PM
11.31.04.37 29.50 Floor Inner Sill to First Groove, left hand, Mk1-5
11.31.04.38 29.50 Floor Inner Sill to First Groove, right hand, Mk1-5
(ignore the price as these are incorrect however it will give you a rough idea of how much they are.)
It still quite a bit of work but a lot easier than chopping out half a full length floor section.I will be using these panels on Project Paddy when i do his resto next year.
Posted 06 June 2012 - 01:29 PM
Posted 06 June 2012 - 01:39 PM
The rear heelboard really needs the rear subframe off to make a proper diagnosis of how bad things are. Once the outer sill is off you will be able to see the subframe mounting captive nut and the reinforcement bracket that is attached to the inner sill. These do suffer quite badly but you will need to do some work in this area when you do the inner sill.
Its not the end of the heelboard if these brackets are rotten. You dismantle it and fabricate a new one out of 1.2mm steel sheet and add a small gusset piece to center of it to give it the strength it needs.
Or you can buy them from Somerfordminis
14A9546 and 14A9547
Posted 06 June 2012 - 01:42 PM
