Hif44/inlet Manifold/spacer/abutment Plate, + Other Odds
6 replies to this topic
#1 stickycreambun
stickycreambun
  • 1,865 posts
Posted 04 June 2012 - 01:25 PM
Apologies for rubbish pics, had to use my phone.
Main item is a SU HIF 44:
Elbow to airbox-HIF44-abutment plate-spacer-water heated inlet manifold, all still bolted together, with gaskets etc.
Im presuming just as it was taken from a car, so in theory could be fitted straight back on again. You would need the little clip for the throttle cable on the abutment plate, and I think it needs the little bitty for the choke cable to screw too as well.
I bought this as it is now but did not get round to breaking it down or using it. Pretty grubby but should clean up fine, the carb seems good from what I can tell. I think the needle was a BFR. The inlets to the manifold are pretty corroded like they get, would be best just to cut them down a bit. Also needs the manifold/brake servo vacuum bolt, but you should have this anyway if you need it.
£72 posted
Also, im trying to clear up my garage so have found an assortment of odd bits and pieces (all pretty grubby but either new or did work ok when I would have removed them) -
Chequered bonnet stripes (black/clear) - £14 posted
New unopened tin of red engine laquer - £10 posted
New unopened pot of Kent cam lube - £8 posted
2x engine mounts, captive nut type - £8 posted
2x 3/8" wheel spacers - £10 posted
2x 3/4" wheel spacers (pretty sure I have the other 2x as well, to be found) - £12 posted
Rad top bracket, 998 fitting. £3 posted
82º thermostat - £3 posted.
Mechanical fuel pump - £10 posted.
Ignition coil, the not-electronic ignition type. £10 posted.
Pretty sure a few more bits are still to come, possibly a MG Metro lump that would be best off being rebuilt...
Collection welcome from Bath, pm me for number if you want to ask anything. I can combine postage for more than one item, just pm or call me.
:thumbsup:
Pics, in order:
Edited by stickycreambun, 04 June 2012 - 04:42 PM.
#2 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 04 June 2012 - 06:33 PM
Do you have any extended studs to go along with the 3/4" spacers, per chance?
#3 stickycreambun
stickycreambun
  • 1,865 posts
Posted 04 June 2012 - 06:59 PM
Ha, I knew someone would ask... pretty sure I do, but cant find them! For now at least. Sorry.
#4 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 04 June 2012 - 07:07 PM
Haha, no worries dude.
Once my arches arrive I'll be able to confirm how wide I need. Chances are I'll need same front and rear.
Update if you find the others ;-)
#5 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 06 June 2012 - 02:09 PM
would buy the carb only, no need for the manifold! But need it to be shipped to Latvia! Can pay with paypal.
#6 stickycreambun
stickycreambun
  • 1,865 posts
Posted 06 June 2012 - 02:19 PM
Would rather sell it together. Someone asked about postage to France already, unfortunately for some reason it costs more than the carb/manifold. Up to you if you wanted to look up your own shipping. Thanks.
#7 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 11 June 2012 - 12:11 PM
Hey sticky,
Did you track down the other 2 spacers by any chance?
