Suzuki Alternator Helppppppp Please
Posted 03 June 2012 - 06:55 PM
any help would be much aprecieated many thank
if u have face book add me an inbox me because ive not much access to computer
anthony nurse look 4 a blue mini
Posted 04 June 2012 - 06:51 PM
After translating your post, On your mini you should have a big brown wire, on which is a 12v permanent. This is a direct link to the battery (3)
There is a brown and yellow which leads to the ignition light, this will supply 12v at the alternator once the ignition is on (1)
A third seperate wire needs to be run from the an ignition live, to the alternator (2)
Edited by charie t, 04 June 2012 - 06:52 PM.
Posted 05 June 2012 - 07:35 PM
Posted 05 June 2012 - 07:50 PM
The big brown wire carries the charge to the battery yes, but will not make the light work. The smaller wire (1) will carry a live feed. The alternator earths this, to light the lamp
the second (2) is a switched live to excite the regulator. once you have this the light will work
Posted 05 June 2012 - 07:55 PM
Posted 05 June 2012 - 08:07 PM
Have you got 12v at that conection? balast igniton won't (pink wire)
Posted 06 June 2012 - 02:41 PM
http://westfield-wor...alternator.html
Posted 06 June 2012 - 02:44 PM
I get that your supplying the ECU with the old coil feed but it really should be fed through a relay and the negative of the coil should be switched by the ecu as per the way that Suzuki did.They also switch the fuel pump relay in the same manner.Okay thank u I will pull the insulation tape off and have a look were they go every body elses conversion I've seen has used the hole suzuki loom were as I've jus got my old coil wire making my ecu live an running the engine if that makes sense
