Caustic Soda To Strip Wheels
Posted 02 June 2012 - 05:01 PM
I am going to start repainting my wheels soon (12" alloys) but i want to strip the paint off first to see if there is any damage to the wheel or just the paint.
I was going to use nitromors to strip the paint but I have herd that the formula has changed and it is rather ineffective.
Can anyone confirm this?
If so, then I was thinking about using caustic soda instead. Has anyone tried it?
Ive seen it works a treat on wood but im a bit worried about putting it on my alloys in case it damages them, and I dont know how long to leave it on for.
Any advice is greatly appreciated.
Posted 02 June 2012 - 06:05 PM
It will very seriously etch the surface, and cause millions of stress raisers, making the wheels totally unsafe. And, it will evolve far more hydrogen gas than it takes to blow you up. Hydrogen ignites very readily, even static electricity will set it off.
Posted 02 June 2012 - 06:44 PM
Posted 02 June 2012 - 07:50 PM
I know all about the dangers associated with NaOH and Hydrogen I just no nothing about alloy wheels so didn't realise the soda would react quite so readily with them.
Guess ill just have to give nitromors a shot then unless anyone knows of anything better?
Posted 02 June 2012 - 09:06 PM
Posted 02 June 2012 - 09:28 PM
It still works, you just have to be patient. It takes days to dry, so what I do is cover the wheels, wait a few hours, coat again and leave over night.... Usually this is pretty much enough. I rub it off with wire wool.
Posted 02 June 2012 - 10:09 PM
Posted 02 June 2012 - 11:32 PM
Then to finally remove it, I used a jet washer. Worked well, but don't do this without eye protection.
Posted 03 June 2012 - 01:09 PM
I always found the most effective mothod of using Nitromores was to coat the item, then stand back ad turn your face away while you pour a kettle of boiling water over it
What does pouring a kettle of water on it do? surely that would wash it off?
Posted 03 June 2012 - 04:21 PM
Posted 03 June 2012 - 07:24 PM
http://www.ebay.co.u...f#ht_4393wt_698
It's very good stuff, probably better than the original Nitromors which was very good.
You should be able to get some from your local bodyshop supplier also.
Posted 03 June 2012 - 07:31 PM
Posted 03 June 2012 - 08:30 PM
Posted 04 June 2012 - 09:18 AM
Posted 04 June 2012 - 03:23 PM
Ive used chemicals at school where labcoat and goggles was all that was needed.
At uni, in the labs, the same chemicals you need to use in a fume cupboard with gloves and coat and goggles.
In industry, your not even allowed to handle them,
yet you can buy them in your local hardware store no bother
