My Dads 1958 Ford Prefect
20 replies to this topic
#16 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 03 June 2012 - 02:56 PM
Yea, Ultralites, white lower flash (same as green car) and dropped a touch with original grille and bumbers - nice car
Wonder why such an original looking car ended up with the orange bling?
We thought exactly the same to be honest, unless they were planning on doing something with it involving the 'orange bling' then decided against it?
Who knows, either way they're long gone! :D
#17 Cooperman
  • 23,569 posts
Posted 03 June 2012 - 06:41 PM
How about a 1500 Cortina GT engine bored to 1650 with a pair of 40 DCOE Webers, a fully flowed head, GT manifold and a Cosworth A2 cam? Add a 2000E gearbox and a 4.1:1 final drive ratio using the Anglia drive shafts/axle and it will be fantastic. You would have around 110 bhp. It would also be reliable and a great road car too.
#18 Ryang556
Ryang556
  • 2,747 posts
Posted 03 June 2012 - 07:54 PM
Sounds almost tempting to get one in the near future... it is a lovely car! Free tax and a possible no MOT soon as well? :shifty:
What's it like to get hold of the engine etc?
#19 twistin rally car
twistin rally car
  • 24 posts
Posted 03 June 2012 - 08:22 PM
its actualy a popular because prefects are 4 door and if he is keeping it original me and my father have some spares such as engine box diffs rads and other stuff
#20 Cooperman
  • 23,569 posts
Posted 04 June 2012 - 10:01 PM
It's certainly easier to get hold of the 1500cc Ford Cortina/Capri/Corsair engines than a Cooper 'S' engine these days.
They are a lovely engine with a 5-bearing crank and a 'square' bore/stroke ratio. The gearbox to have is the Corsair 2000E one as the gear ratios are superb. If a 'hot' cam and twin 40 DCOE Webers are used a low final drive is needed and the 4.1:1 out of the Anglia 997/1200 would be ideal. Compared to a Mini the Ford is just so easy to work on so long as the base car is the one which had the 997 engine rather than the earlier 1172 side-valve unit.
The suspension is easy to sort as inserts can be fitted to the original struts and higher-rate coil springs will go on the front. On the rear a set of Escort Van leaf springs with telescopic dampers would be easy to engineer to fit.
You know, built like that it would have the performance of the old Escort Twin-Cam. Wow, quicker than a Cooper 'S'.
I'm almost tempted to build one myself!
#21 miniman retford
miniman retford
  • 3,553 posts
Posted 05 June 2012 - 09:36 AM
I had one of these in my younger days. Had an mga 1500 engine & box fitted :D
