5,7 or 8 port - pros and cons etc etc
#46
Posted 05 September 2007 - 12:21 PM
#47
Posted 05 September 2007 - 12:24 PM
Hiya,Bill Richards here.I have built a few 8-ports in my time.we have built 8-ports on Amals ,modern bike carbs and webbers.The bike carbs showed the same top end power as the webbers and they fit under a standard bonnet.I to will be at castle combe and will be only to happy to answer any questions anyone has.The 8-port is quite a complicated engine but when buit right it is bullit proof.If built right you can use standard pushrods.
Cheers Bill, thanks for your sound advice. I like the idea of bike carbs under a standard bonnet but have been told that amals are hard to tune and only work either flat out, or turned off!
In your opinion could a 7 port be as powerful as an 8 port and used sensibly on the road?
+ bill is the best
#48
Posted 05 September 2007 - 12:57 PM
Hi Tom.An 8-port will alwayas have the edge due to its superior design.Due to the amount of torqure they produce they drive easily so using big power ones on the road is a doddle.We used to run ours on carbs from a modern 1100cc bike
Cheers Bill, much appreciated. I may in touch in a the not too distant future about an 8 port
#49
Posted 01 December 2007 - 12:54 AM
hi , i had an original akm 7 port head with amals , it was built as a fast road car and even the wife found it very drivable , even with a 649 cam, loverly flat torque curve, just great great funHi Tom.An 8-port will alwayas have the edge due to its superior design.Due to the amount of torqure they produce they drive easily so using big power ones on the road is a doddle.We used to run ours on carbs from a modern 1100cc bike
#50
Posted 30 September 2009 - 02:04 AM
Separate inlet manifiold for 2xDCOE carbs or DCOE base plate design injection throttle bodies.
email:[email protected]
web site www.kenelderandsonsptyltd.com.au
Edited by crossflow, 30 September 2009 - 02:11 AM.
#51
Posted 01 October 2009 - 01:51 AM
Ken Elder (Australia)Now makes 7&8 Port alloy heads for "A" series engines
Got excited when I saw this as I am in Australia so I e-mailed to get some more info:
Hmmm not convinced:
They make 8 and 7 port versions, both use standard cams which makes me wonder how the 8 port works, would think it has very restricted exhausts on 2&3 cylinder.
Cost works out to be more expensive than an Arden 8 port: Built up head is $3250 Australian about 1780 pounds, Equivalent Arden from Minispares is 1548 pounds.
Also cannot get 8 port exhaust so would have to make your own. Only inlet manifold is for Webbers so again would have to make your own for anything else.
I think you would have to expect to do a lot of development yourself to get this to work...
#52
Posted 04 October 2009 - 10:31 PM
Hmmm not convinced:
OK been looking into this a bit more getting much more convinced!
Those interested :http://www.ausmini.com/forums/viewtopic.php?t=54673&postdays=0&postorder=asc&start=0
7 port looks very good, far better than the Minisport one...
#53
Posted 03 January 2010 - 02:25 PM
#54
Posted 03 January 2010 - 07:09 PM
