5,7 or 8 port - pros and cons etc etc
#16
Posted 09 March 2006 - 09:13 AM
Is the 7 Port head a bolt on head? I know its not "bolt on" but do you need speacial things to be able to run it, such as the cams etc with the 8 port or S rods when stroking a crank. Or can you just use the head on a normally built engine
#17
Posted 09 March 2006 - 09:55 AM
With the Arden 8 port, apart from the cam, you also need special pushrods, and there are several ways around this. Some people get custom carbon ones made up, otherwise grind some down, or I think it *maybe* possible to use pushrods from another Austin engine, but again, not too sure on that.
Another thing to consider with 7 and 8 ports and 16Vers is that you need special bonnets to clear either the carbs or the cam cover.
#18
Posted 09 March 2006 - 10:00 AM
Not if I can Help it
#19
Posted 09 March 2006 - 10:19 AM
I do see the logic of using a 7 port head, they utilise the same camshafts, exhausts etc, but with the added benefit of increasing your fuelling options. So you can get the best of both worlds, you can modernise the fuelling of an A-SERIES ENGINE without loosing the benefit of hundreds of other well-established bolt on mods (cams, exhausts etc).
As for 5-port heads, they are ultimately what limits and restricts THE A-SERIES ENGINE IMHO.
Sorry to accentuate the A-Series bit so much, I just didn't want to go off topic at all!!!
#20
Posted 09 March 2006 - 10:45 AM
Charlie
#21
Posted 09 March 2006 - 01:26 PM
One other thing I was thinking of when reading oldschool's thread, what would a supercharged 7 port be like?
#22
Posted 09 March 2006 - 06:03 PM
Oldschool - how long did you have to wait for yours?
Now just need to sort out an overal engine spec and i can start getting bits and pieces
#23
Posted 09 March 2006 - 06:06 PM
bit of a sore point for Brett that one! shhhhh
#24
Posted 09 March 2006 - 06:10 PM
#25
Posted 09 March 2006 - 06:19 PM
#26
Posted 09 March 2006 - 08:24 PM
you can get bonnets with an added bulge tho that dont look tooo bad
#27
Posted 09 March 2006 - 08:28 PM
#28
Posted 09 March 2006 - 09:03 PM
who_loves_the_mini? Posted Today, 06:03 PM
Ive decided to go 7 port. After having a think today I reckon i should be able to order one at the end of April if everything goes well, maybe a bit sooner
It took just over 2 months and that was with no chamber and port work carried out. Minisport initially said 5 weeks but I knew it would be longer a they were sorting out the casting problems when I first ordered.
As for the fitment, the only things that will be needed is a set of carbs or throttle bodies. I got mine off Ebay and was first considering fitting GSXR1000 throttle bodies, but when looking at it, Id have to have manifolds made up and Id rather do that when I add the Garret T2 turbo at a later date.
#29
Posted 10 March 2006 - 09:27 AM
Im going to go for a set of twin weber 40's if I can find a pair in decent nick.
Before i can order the head though im getting the bodywork sorted and the 1275 completely rebuilt but with the standard head. Once the mini is solid and sprayed ill order the head so should be fitting it around the summer hopefully
#30
Posted 11 March 2006 - 09:17 AM
As for carbs, I was going to fit twin 45 Webers until I read that it is actually better to use Dellortos on the 7 Port. Bassically you can finely tune them more than the weber and this is what is needed for this head in particular.
