Caliper Bolts Stuck - Heat Gun Good Idea?
Posted 02 June 2012 - 11:22 AM
Mini Cooper 1998 MPI
Posted 02 June 2012 - 11:25 AM
Posted 02 June 2012 - 11:26 AM
I wouldn't put heat near the rubber brake hoses, or the caliper containing flamable brake fuid
Posted 02 June 2012 - 11:33 AM
Posted 02 June 2012 - 11:42 AM
Just use penetrating fluid (that is not WD40, you need proper pen. fluid), then a good quality 9/16" AF socket and a long bar. If the bolt head has rounded you could get a 14 mm socket and hammer it on then use a long bar, but that could damage the socket (still, they are not expensive).
Posted 02 June 2012 - 11:53 AM
Posted 02 June 2012 - 12:06 PM
Thanks for your response all of you. It is invaluable help for me to get this kind of advice! I have been using a ringspanner, and connected a larger ringspanner to it to get a bit more leverage. I have also sprayed them with WD-40 for a few days. I'll try and source 6-sided pipes and see if it helps. Seems mine are all 12 sided.
And use a proper penetrating fluid first. A lot of people think WD40 is the right thing for this, but it's most definately not. You need 'Plus-Gas' penetrating fluid or its equivalent. 12-point socket should be OK if the fluid has worked its way in. A quality 1/2" square drive socket set is essential for working on a Mini.
Posted 02 June 2012 - 12:28 PM
I have been using WD-40 for years, and not known it was the wrong tool! It often does not work, just like you said. I'll go and buy Plus-gas or similar, and see if it helps. This advice will help me in all my future work too!And use a proper penetrating fluid first. A lot of people think WD40 is the right thing for this, but it's most definately not. You need 'Plus-Gas' penetrating fluid or its equivalent. 12-point socket should be OK if the fluid has worked its way in. A quality 1/2" square drive socket set is essential for working on a Mini.
Posted 02 June 2012 - 01:27 PM
Another possibility after you have applied the penetrating oil and allowed it time to work is to use an impact wrench instead of the paired ring spanners or a socket with breaker bar. The impact wrench will apply mechanical shock to the fasteners that should help break them loose.
Posted 02 June 2012 - 01:39 PM
Posted 02 June 2012 - 02:03 PM
I am removing it from the car in order to change pistons and rubber seals. Hopefully the calipers itself is OK. Now proper penetrating oil is soaking, so hopefully the bolts will be out soon.Are you splitting the caliper or removing the caliper from the car? Back in the day... we were always told to NEVER split a caliper. Today people seem to do it quite a lot.
I don't have access to air tools unfortunately, but I have new faith they will come out now.
Posted 02 June 2012 - 02:18 PM
With an impact driver you use heavy duty sockets or bits on what looks like a steel screwdriver handle. You put the socket on the bolt, turn the handle the direction you want the bolt to go, then strike the end of the handle with a heavy hammer. The heavier the better. Cams inside the handle impart a very strong shock load and torque to the fastener and help brake it loose. Just don't hit your hand by mistake! The impact driver is a must have tool if doing heavy machine work and no air power is available.
The picture link below is for an impact driver.
http://www.toolnet.c...mages/47641.jpg
And the link below shows a person using an impact driver to remove brake parts from their car.
http://www.bombaydig..._driver_lg.jpeg
Posted 03 June 2012 - 09:56 AM
It's on the shopping list!An alternative to the air impact gun is an impact driver. .
Posted 03 June 2012 - 10:10 AM
