#16
Posted 27 April 2006 - 11:42 AM
Mini in the park is on 20th august 2006 so hopefully youl have it done by then?
keep up the good work your doing a brilliant job so far
wayne
#17
Posted 27 April 2006 - 01:03 PM
Funny you should mention the paintwork - it had an awesome finish to it and it was a great colour - Ford Imperial Blue (as used on the Cosworths I believe). It just staggers me to think that all the time and money prepping it/painting it was wasted by not protecting any of the bodywork to actually make it last.Good project and its nice to see a proper clubman being restored i soo miss mine, yours does in deed look like it was bodged heavily but alot of people seem to be doing that lately and doing a good paint job to cover it which seems silly in my eyes
wayne
I found some photos of it when I had it on the road and it really did look good - it was just rotten underneath the paint and filler.
As for MITP2006 - I think I'll be lucky to make it. I might try and do the minimum to get an MOT (i.e. leave out interior trim etc) and then at least I can drive it home to work on the rest.
#18
Posted 27 April 2006 - 01:22 PM
I did this with mine, and due to other commitments i havent really progressed with the interior, but it hasnt stopped me buying new bits to put on it, just need to get around to putting them on, which shouldnt be long till i have the time.
Really is looking good though, when i first saw the painted car (without seeing the work and preperation behind it) i thought you had just bought a new shell (just like the one in the mini mag).
#19
Posted 27 April 2006 - 01:59 PM
In hindsight I should've bought a new shell really - although because of the price of mini panels it wasn't very expensive, just very time consuming, and I've always been working on a budget.Really is looking good though, when i first saw the painted car (without seeing the work and preperation behind it) i thought you had just bought a new shell (just like the one in the mini mag).I might try and do the minimum to get an MOT (i.e. leave out interior trim etc) and then at least I can drive it home to work on the rest.
The blaze clubman in Mini magazine is great - something for me to aim for. The price of the interior on that car is kinda scary though. It says he paid a grand for it in total.
#20
Posted 29 April 2006 - 01:05 AM
Yes exactly what i mean ive been looking at a few minis for sale and the finnish looks original and clean but then you think why have they smoothed the wings into the scuttle and not anything else etc and you sloly realise its all bodged and yes imperial blue is the proper cossie colourFunny you should mention the paintwork - it had an awesome finish to it and it was a great colour - Ford Imperial Blue (as used on the Cosworths I believe). It just staggers me to think that all the time and money prepping it/painting it was wasted by not protecting any of the bodywork to actually make it last.
Can you host up the pics of it when you first had it
Mini in the park 06 is a close aim ill admit im hopefully going (have no mini but anyway) would be nice to see a clubby without a vtec they seem rare these days
good luck with the project its worth it in the end
wayne
#21
Posted 27 July 2007 - 02:32 PM
The project is taking a lot longer than first expected because (a) I'm a bit of a perfectionist so nothing is going back on the car until it's cleaned, painted or polished and (b) the car is in a workshop 75 miles from my home
Anyhow progress is being made slowly. Brakes are all refurbed and on the car incl. the MkII Fiesta front set up. Handbrake is installed and functioning. Pedal box has been removed. unsiezed, lubed up, painted and re-installed. Suspension is complete bar the front dampers & brackets.
Turbo engine is prepped and ready to go in (gaskets/seals changed and all clean and painted).
Stuff I'm working on at the moment (for the next trip back to the workshop) are transfer case, clutch, clutch cover/lever & mech and the gearchange rods + housing - all with the aim of getting the engine off the stand, bolting on all the new refurbed clean bits and dropping it into the shell. Wish me luck!
Some piccies:
Fiesta brakes
Cheers,
Mart
#22
Posted 27 July 2007 - 05:58 PM
Edited by ROD, 27 July 2007 - 06:45 PM.
#23
Posted 27 July 2007 - 06:06 PM
#24
Posted 13 August 2007 - 06:14 PM
First little problem stopping me fitting the engine was a broken exhaust manifold stud
This was going to go one of two ways - either the whole day was going to be spent trying to get it out or it would come out within half an hour.
Luckily it was the latter
Anyway this allowed me to progress onto fitting the flywheel housing, new clutch and flywheel, clutch cover, new clutch lever/slave cyl./bracket etc. At the other end the timing chain cover was refitted with a new gasket and new driveshaft and gear selector rod seals were fitted.
So after a good 5 hour stint I connected the lifting shackles and dangled the heavy lump over the front of my restored car and carefully lowered it into place.
Job done and well pleased.
I also refurbed the rod change assy but didn't get round to fitting it this weekend
Now onto the cooling system and generally concentrating on getting her running........
......unfortunately I discovered today that the turbo is fekked. My engine came from my boss' crashed metro and the collision was large enough for part of the centre casting on the turbo to be cracked and the turbo shaft to be bent
I've got a couple of spare turbos so hopefully I can rebuild one of them to a useable standard.
Mart
Edited by sherly, 13 August 2007 - 06:15 PM.
#25
Posted 30 November 2007 - 01:08 PM
I've been concentrating on plumbing in the cooling system and sorting out all the engine ancilliaries.
Cooling wise I've gone for a front mounted early metro rad and associated pipework. There was a little cutting and shutting of the front end panelwork to get it to fit with enough clearance to the dizzy. This wont be an issue eventually as I intend to go for a megajolt setup once the car is MOTd and on the road.
I'm back working on the car this weekend - high on the priority list is to heatshield the bulkhead and then fit all the engine ancilliaries once and for all (and clean everything up). My aim is to have the engine running by xmas (turning the key over the 15th/16th Dec all being well!)
#26
Any opinions welcome.......
Edited by sherly, 30 November 2007 - 01:11 PM.
#27
Posted 01 December 2007 - 08:12 PM
Thought it was about time I updated my project thread. I've been working on it for several weekends since the engine went back in, in August.
#28
Posted 07 January 2008 - 02:31 PM
The weekend before xmas I returned to the workshop after buying a pukka coil and an ign module with the intention of fitting them, getting a spark and firing the old girl up.
The first thing I managed to do was bust off one of the lugs on the coil
In turning over the engine it soon became evident that I had a pretty big fuel leak from the carb. Leaking to the point where the bores were filling with fuel....... So it was game over in respect to starting the car before xmas - I whippped the carb off and brought it back home to rebuild.
This is what I found when I removed the float chamber base....
Grim!
£50 later and freshly rebuilt over this weekend this is what it looks like now....
Also tried out the polishing kit that I got for xmas on the dashpot cover - not sure how long it'll last like this but it satisfies my OCD-like tendancies for cleanliness
So - back to the workshop next weekend to bolt it on a fire her up.............
......maybe
#29
Posted 07 January 2008 - 03:07 PM
Rhys
#30
Posted 07 January 2008 - 04:03 PM
I've done everything myself so far, regardless of past experience, just to further my skills and knowledge. I bought a second hand compressor fairly cheap, a half decent spray gun and had a crack at it. I'm really pleased with how it has come out. It's not A1 perfect by any stretch but it does looks great, even close up!I have a 1275 GT and that really does inspire me and i love the colour, as you did it yourself did you use proper equipment, air compressor and spray gun? The engine bay is awesome looks really good and clean. Good Job!
Rhys
One job I'll probably bottle out of is retrimming the webasto roof - just because I want it finished and on the road now!
Also tagged with one or more of these keywords: clubman
Projects →
Mini Saloons →
Black 1979 1275GtStarted by StuaR32t , 15 Feb 2025 ![]() |
Projects →
Mini Saloons →
Cape Town 🇿🇦 1275HleStarted by JAYO , 28 Feb 2021 ![]() |
Projects →
Mini Saloons →
Budget Mini Clubman Shell Restoration For £1500Started by minimissions , 13 Nov 2019 ![]() |
Projects →
Mini Saloons →
1275Gt Tarmac Rally Car - From ScratchStarted by KRM_Simon , 26 May 2019 ![]() |
Projects →
Mini Saloons →
1275Gt Resto - From Flip To FactoryStarted by Verderad , 12 Mar 2018 ![]() |
