if your mini has been running a bit too warm in the hot weather then you can replace the thermostat with a blanking sleeve so that your engine runs a bit cooler as there is more flow (do not run the engine without a thermostat or blanking sleeve installed)
first of all, remove the radiator top bracket by removing the 7/16 bolts in the cowling and the 1/2 nuts on the thermostat housing
next, remove the top radiator hose
remove the thermostat housing and thermostat, get some tissue to soak some of the water out.
this is the thermostat blanking sleeve next to the old thermostat.
place the blanking sleeve into the cylinder head and fit a new gasket
rub some copper grease on the studs to prevent corrosion/difficulty removing the thermostat housing in the future
replace thermostat housing
replace radiator top bracket and top hose
top the radiator up with water/antifreeze
run the engine and check for leaks.
the job takes about 15 minutes from start to finish.
Edited by oltonlad, 26 May 2012 - 12:27 PM.
