Ive got to replace a rear brake cyclinder that has leaked over every thing. The thing is, I can get some stuff to clean the drum but can I do the same with the shoes and use them still?
Reuse Rear Brake Shoes!
mayhem13
, May 24 2012 06:14 PM
7 replies to this topic
Posted 24 May 2012 - 06:14 PM
Posted 24 May 2012 - 06:31 PM
New ones and you have to do both sides,they are only about a tenner
dave
dave
Posted 24 May 2012 - 06:42 PM
As above, if they're contaminated they're only fit for the bin!
Posted 24 May 2012 - 06:48 PM
Nice one, I thought that. And I going to need a bucket of fluid to. I'll fix and repair anything on a mini but bleeding brakes I hate.
Posted 24 May 2012 - 09:35 PM
Be sure to replace the other wheel cylinder, as they have both had exactly the same amount of use. If one fails, the other is not far behind, and you don't want to do the job twice.
Posted 24 May 2012 - 09:51 PM
If your stuck you can boil the fluid out of the linings in a pan of water
Dont tell her indoors though.
Posted 26 May 2012 - 02:52 PM
Did the job I hate. But had a ezbleed kit and it made it easy. Changed brake fluid at the same time and the stuff that come out was cloudy and dirty, shocking!
Posted 26 May 2012 - 04:07 PM
B esure to also free off the levers inside the drums - and the connections to the cables (should swivel freely) and also free the quadrants on the trailing arms and grease the slides where the cable(s) run. Slacken back the handbrake adjustment - set up the rear brakes (free off and grease the adjusters..) and then finally re-set the handbrake adjustment. Now you have 'good as new' rear brakes - should be able to lock the wheels at 20 mph.
