Its been far to long since i've done an update, so got a little one here
Got home last week and was welcomed by a delivery from Allspeed and Powerflow. It was like Christmas day aaaaaall over again
So yesterday I set about tinkering, didnt plan on doing vast amounts because I aint got a clutch M/C yet because everywhere in the country is out of stock
, i like to have everything I need to finish the job. But I got the alternator mounted up.
Oh and question for anyone who uses this mounting...what belt did you use? All the ones i took off the honda engine are too big and my peugeot spare one is too small....typical
Bit close??
Also got my pedal box bolted up, the clutch pedal is very close to the heater but got a plan for it. Managed to modify the accelerator cable and attach it to the pedal feels nice and can be adjusted. Also modified the heater valve cable to tidy up the 'bay
Got my master cylinder bolted up, just as i bolted it up i remember about a gasket i need for under the master cylinders??
Cheeky shot of the braided hoses there
They are soooo nice, would recommend Powerflow anyday. I aint got a servo on this car, i aint driven a car without a servo so this could be interesting, my Peugeots brakes are very solid so its good training
The route of pipes are very simple, fronts are M/C to T-piece then to brakes and the back line goes through the Wilwood bias valve
All needs tidying up and i'm going to buy one of those speaker boards for under the back bench so will bolt the bias valve to that and tidy it up later
Finally I got the driveshafts all put together, love working with nice clean parts.
Need to get clamps for the inner cv's but its all together. By far the messy-ist job i've done on the car up to now
All I'm needing now is clutch master cylinder and seats along with lots of other small bits and bobs and this should be driveable (touch wood). The AP racing M/C should be available at the end of January so thats my goal. Getting exciting now
new year resolution is to get this car finished......
Hope everyone had a good festive period
Kieran
Edited by KieranB, 13 January 2013 - 06:46 PM.
