Boot Seal Question
Posted 20 May 2012 - 10:10 AM
Renny.
Posted 20 May 2012 - 10:29 AM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sideways.gif)
Posted 20 May 2012 - 10:35 AM
Rhys
Posted 20 May 2012 - 10:39 AM
You get an early seal and late seal. The early seal fits on the actual boot lid and the late seal around the boot panel as you have mentioned. Usually cars after 88 user the late seal. Unless your boot at some point has been changed (like mine was
) As far as I know it's not interchangeable which one you use. I have the early seal and I have never had a problem with water getting in.
Thank you for the help!
the owner of the mini i brought had reversed in to something and its slightly misshaped the boot panel so the top corners of the boot lid are slight out and therefore gaps which im trying to correct as i dont want the boot to leek for obvious reasons :)
Edited by Renny, 20 May 2012 - 10:42 AM.
Posted 20 May 2012 - 04:13 PM
Posted 20 May 2012 - 04:40 PM
