Best Way To Treat Rust Bubbles...
Posted 17 May 2012 - 03:44 PM
Seen a few rust treatment kits (gel and primer) etc
but with the weather as it is, and lack of a garage to keep him in
is it best to wait for when it'll def. be dry for a few days? or get it done?
can it be treated and primed and left for a bit until i get hold of some paint? metallic brg if anyone has any they dont need/want!
Cheers!
Posted 17 May 2012 - 03:49 PM
you can get just a little bit if surface rust under there, which is easily attacked with a wire wheel and then etch primed, primered then painted
but you could also have rust holes, which obviously would have to be welded up.
have a poke around, see what the situation is with the rust, if there is solid metal under there, you should be able to tackle it all in one day, hopefully avoiding rain. but if there are holes, it will take longer as it will require more work to make good. So id leave that until a definite period of good days:)
Posted 17 May 2012 - 03:54 PM
dad said something about filling them if need be. filling with....?
Posted 17 May 2012 - 03:58 PM
Posted 17 May 2012 - 04:08 PM
Posted 17 May 2012 - 04:10 PM
i think the best tool for removing rust like this is with a knotted wire wheel that can be used on a grinder, these are really awesome bits of kit ( use goggles and thick welding gloves, when the wires come out or if it hits your hand, it hurts!!)
this will totally remove all rust and make it new metal. as your dad was saying, if its bad surface rust it will need filler. This is most commonly body filler, you can get it from halfords etc. this is becuase the rust can cause pits in the metal, and when painted, you would see them.
so, after going over the rust with the wire wheel, i would primer the are metal, then filler and smooth off untill good, then get a bodywork person to spray the repaired area, if it is hand painted it will look terrible as it is a metallic paint.
it may cost a bit to do ( bodywork wise) but with new seals and fresh metal and paint, it should not rust for a few years!
get some pictures of the rusty area up! please:)
Edited by MiniclubmanGT, 17 May 2012 - 04:28 PM.
Posted 17 May 2012 - 04:21 PM
personally, if im doing a job, id do it right. when the time is right( not going to rain, dont need the car for a few days) i would get the rear sreen out and get replacement seals. sand back the area around and on top of the rust bubbles, pretty much back to bare metal around the rust bubble, then asses. if it is just surface rust, then what im about to write should be a good guide to follow. if it has rusted a hole, you better crack the welder out ;)
it may cost a bit to do ( bodywork wise) but with new seals and fresh metal and paint, it should rust for a few years!
Finally, someone who does a proper job, not a half arsed one.
Posted 17 May 2012 - 04:35 PM
Theres the main bits!
Edited by abbymichelle, 17 May 2012 - 04:36 PM.
Posted 17 May 2012 - 04:37 PM
image-1.jpeg 32.11K 30 downloads
image-2.jpeg 30.74K 17 downloads
image-3.jpeg 30.69K 14 downloads
image-4.jpeg 33.02K 15 downloads
nope, it didnt like that :)
but then i say that, it works in the quote bit :S
for the rear screen rust, i fear that there will be rust holes, the rust has gone from rust bubbles to rust volcanoe! meaning lots of rust, which then will mean rust holes
Edited by MiniclubmanGT, 17 May 2012 - 04:40 PM.
Posted 17 May 2012 - 04:42 PM
oopsie
Posted 17 May 2012 - 04:49 PM
Posted 17 May 2012 - 05:13 PM
Posted 17 May 2012 - 05:21 PM
Edited by leaky, 17 May 2012 - 05:22 PM.
Posted 17 May 2012 - 05:22 PM
A few months later it was back.
Cut out the rot and weld in new metal, which is what I have just had to do, these pics were taken last summer. I have now replaced the whole front end.
Best way forward
Edited by mymini007, 17 May 2012 - 05:31 PM.
