Stupid Question But Necessary: Heater Valve Positon - Which Way Do I Pull?!
30 replies to this topic
#16 Jakeclubby
Jakeclubby
    Previously known as Jakemayfair
  • 1,669 posts
Posted 17 May 2012 - 04:03 PM
What cable is this
#17 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 17 May 2012 - 04:29 PM
The heater control is via a cable, which operates the valve.
#18 autonwolf
autonwolf
  • 15 posts
Posted 17 May 2012 - 08:00 PM
Please please forgive me, but I am extremely inept when it comes to the mechanical aspect of cars :( I hope this car will improve this inability rapidly :P But for ONE CARB OR TWO, Here are some snaps of under my bonnet, can you determine which position it would be from these pictures? By the way, apologies for the very dirty appearence, it's measly in comparison to the images you provided :P
Attached File  Screen Shot 2012-05-17 at 20.58.51.png   764.98K   87 downloads
Attached File  Screen Shot 2012-05-17 at 20.58.42.png   788.52K   48 downloads
Attached File  Screen Shot 2012-05-17 at 20.58.31.png   773.21K   58 downloads
#19 Spitz
Spitz
  • 1,716 posts
Posted 17 May 2012 - 08:18 PM
Those pictures show the valve on the head.
This would mean pushed in for heat...pull knob out for cooler air
#20 autonwolf
autonwolf
  • 15 posts
Posted 17 May 2012 - 09:34 PM
Thanks alot folks! Will give it a try this evening and tell you how it gets along, just hope this old beast isn't too clogged :P
#21 jakejakejake1
jakejakejake1
  • 644 posts
Posted 17 May 2012 - 10:20 PM
Just to add, even after you switch to cold, it will still blow hot air for a while as there is a still warm fluid in the heater matrix. Once this cools down then cold (ambient) air will be blown.
Also there is a good chance the valve is seized, maybe not completely but it may be worth oiling it and the cable.
My heater had two hot settings, really-hot and slightly-less-really-hot until i oiled up the valve and cable :)
#22 autonwolf
autonwolf
  • 15 posts
Posted 18 May 2012 - 12:01 AM
I attempted to test it this evening but no hope, there is no warm air coming through, I wondering whether it is clogged now and/or needs an oiling, could anyone please perhaps give me some guidance or links on how to go about this,
Thanks greatly :)
#23 jakejakejake1
jakejakejake1
  • 644 posts
Posted 18 May 2012 - 10:16 AM
Shown in the picture (Red Circle) is the valve, get someone to help you, and push/pull the knob and see if the valve moves at all.
If it does and also if you have a temperature gauge check the engine is actually getting up to temperature, as if the thermostat is stuck open the coolant won't get up to temperature and the air will not get hot.
If the valve is stuck then just put oil where the yellow arrows below show, basically everything that looks like it should move.
#24 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 18 May 2012 - 10:18 AM
mine is either hot when pushed in or boiling when pulled out.
its a heater not a fan.
#25 surfblue63
surfblue63
  • 2,539 posts
Posted 18 May 2012 - 12:48 PM
By the looks of the picture, in the above post, it would appear that your heater valve is already open. Check its' operation, as mentioned above, to get it working. If you still do not have heat then it is possible that your heater matrix is clogged up and nedds either flushing out or replacing.
#26 DClarke1954
DClarke1954
  • 83 posts
  • Local Club: Essex Mini Club
Posted 16 December 2024 - 02:43 PM
As I can pull the dashboard knob with the fiery flames symbol fully out of the dash with it's inner-wire attached I think it might be safe to assume that there is no heating available.
Especially as when looking on the cylinder head where I expected a control-valve and heater tubing to be there is a vacant space.  Why?  You only have to sit in the car and take 2 deep breaths in and out and all the windows fog up for goodness sake.  How on earth are Clarissa and I going to successfully go dogging in this?  :D
#27 Quinlan minor
Quinlan minor
  • 1,180 posts
  • Local Club: LSMOC
Posted 16 December 2024 - 03:50 PM
Edited by Quinlan minor, 16 December 2024 - 03:57 PM.
#28 Quinlan minor
Quinlan minor
  • 1,180 posts
  • Local Club: LSMOC
Posted 16 December 2024 - 03:55 PM
Please please forgive me, but I am extremely inept when it comes to the mechanical aspect of cars sad.png I hope this car will improve this inability rapidly tongue.png But for ONE CARB OR TWO, Here are some snaps of under my bonnet, can you determine which position it would be from these pictures? By the way, apologies for the very dirty appearence, it's measly in comparison to the images you provided tongue.png
The problem may well be an airlock in the heater hose.
Simple enough to check/resolve.
Since you are on your admission "extremely inept when it comes to the mechanical aspect of car"(s), it might be best left to someone with skill.
#29 sonscar
sonscar
  • 3,002 posts
Posted 16 December 2024 - 06:10 PM
Later cars do not have the valve on the head,it being replaced with a plastic valve floating near the wiper motor area.Steve..
#30 colinf1
colinf1
  • 1,015 posts
Posted 16 December 2024 - 08:26 PM
On my car (83) it's pushed in for heat, then for cold its out -;stops the flow of water into heater matrix.
On later models with inline valve it's pull out for heat and in fully for cold
