Stupid Question But Necessary: Heater Valve Positon - Which Way Do I Pull?!
30 replies to this topic
#1 autonwolf
autonwolf
  • 15 posts
Posted 17 May 2012 - 11:48 AM
Attached File  Screen Shot 2012-05-17 at 12.46.10.png   431.49K   47 downloads
A recent mini owner and this being my first car, I'm gradually becoming more and more acquainted with the beautiful quirks of a classic car, but just a quick one, on my 1989 Rover Mini, I'm uncertain which way to pull the heater valve for hot air? i mean i've been fiddling and just can't seem to figure it out, I'm aware that the heater matrix may be blocked and/or need replacing, but just for peace of mind and for the future, I would really like to know what position in the valve should be pulled at for the hot air, whether it be out and turned? or just out, or in and turned etc etc etc. I really hope you can help, many thanks ;)
Attached File  DSCF9845.JPG   41.57K   20 downloads
Edited by autonwolf, 17 May 2012 - 11:50 AM.
#2 minimaxie
minimaxie
  • 1,687 posts
Posted 17 May 2012 - 12:09 PM
on mine its pull out for hot heat, push in for cold.
#3 paul748
paul748
  • Just Joined
  • 80 posts
Posted 17 May 2012 - 12:32 PM
What car is yours?...if the valve is on top of the cylider head,with the control knob pushed in, the valve is open, allowing water to circulate through the heater matrix.Not sure about later bmodels though.
Edited by paul748, 17 May 2012 - 12:34 PM.
#4 DanFuke
DanFuke
  • 338 posts
Posted 17 May 2012 - 12:33 PM
That's correct...with the control knob pushed in, the valve on top of the cylider head is open, allowing water to circulate through the heater matrix.
Is that not the other way round then?
For mine its push in for hot air (like you said as it circulates water) and pull out for cold, not sure why you would want cold air though!
#5 autonwolf
autonwolf
  • 15 posts
Posted 17 May 2012 - 01:00 PM
Thanks for your input! But what model mini/year is yours, just really attempting to identify if anyone has the same model/year and see how it works for them :)
#6 minimaxie
minimaxie
  • 1,687 posts
Posted 17 May 2012 - 01:01 PM
ive got a late 1998 MPi cooper so dont know if that helps, most likely not
#7 autonwolf
autonwolf
  • 15 posts
Posted 17 May 2012 - 01:07 PM
Possibly, i mean it seems so simply right? Just what way do you pull, but i've read many places now that during the mid80's-early90's it was altered, why?! Can't seem to find any definitive threads around anywhere neither giving precise answers so hopefully I'll draw others in with similar models tell me how theirs does,
Does anywho know where you can find the manuals online perhaps?
#8 DanFuke
DanFuke
  • 338 posts
Posted 17 May 2012 - 01:15 PM
I have an 85 Mayfair, not sure if this helps lol!
#9 minimaxie
minimaxie
  • 1,687 posts
Posted 17 May 2012 - 01:35 PM
do you have a haynes manual? might be of help, only way to be sure is fire up the old girl pull out the cable see what happens, if its hot theres your answer!
#10 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 17 May 2012 - 01:42 PM
Didn't realise it varied mine is a 1993 rio you pull it out for hot air andpush it in for cold it does spin but that's irrelavant just how the pull knob sits.
It links to a pipe in engine bay at the top close to the bulkhead behind the thermostat will be some black tubing with a plastic and metal component halfway along this is the control valve the wire coming off it leads into the car to the pull knob.
That is if it's the same not sure how it varies between models should cover it in Haynes though hope that makes sense.
Removing the heater and cleaning it out is easier than it looks and the Haynes talks you through it :D
#11 paul748
paul748
  • Just Joined
  • 80 posts
Posted 17 May 2012 - 02:47 PM
1987 998....valve fixed on cylinder head..control knob pushed in = heater on. control knob pulled out = heater off. It does not make it 'cold', just stops water flowing into the heater.
On later models with the valve in the hose it looks like it's opposite.
>DanFuke..my mistake in the previous post, I tried to edit it but failed.
#12 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 17 May 2012 - 02:56 PM
By the looks of the heater control you have the type were it is pull out for heat and push in for cold. The easiest way to tell which system you have is to look at the cylinder head on the left as you look at the car.
If it is like this with what looks like a blanked hole the it is pull for heat
If it is like this, with a valve on the head, then it is push for heat
Edited by surfblue63, 17 May 2012 - 02:57 PM.
#13 Jakeclubby
Jakeclubby
    Previously known as Jakemayfair
  • 1,669 posts
Posted 17 May 2012 - 02:59 PM
Mine works for heat both ways :L
#14 surfblue63
surfblue63
  • 2,539 posts
Posted 17 May 2012 - 03:09 PM
The either your cable has snapped or your valve is faulty.
#15 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 17 May 2012 - 04:02 PM
