Mg Metro Cam - Kent 266 Similar - Info
16 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 12 May 2012 - 05:28 PM
done a bit of a quick test today on my engine
for those deciding about cams for their car
mg metro cam in a mg metro engine slightly modded
now in fourth gear at 2000 revs its fine, drives ok ( 3.44 diff )
put boot down and pulls straight away, once reaching 2750
you can feel it to realy start to pull all the way to 5500
it may well still pull after that havent tried it
3rd was the same 2750 rpm.
hope this helps with cam choice, particulary for daily car
mines not a daily but very happy with this
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 12 May 2012 - 07:37 PM
the MG metro cam and the kent 266 cam are both excellent fast road camshafts, i think that the problem is (especially with the younger/inexperienced mini owners) is that they think that a rally spec cam (such as the kent 286) is better because its a "rally" cam....this is not the case, the kent 286 cam is ok if you drive your mini everywhere at revs ABOVE 3000rpm in top gear ALL of the time (which would mean that you are always breaking the speed limit all of the time) and i know that some of the youngsters are going to be saying " i do drive everywhere flat out".......well its your funeral if thats the case!!
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 12 May 2012 - 07:44 PM
and before anyone asks if i have had experience of a 286 cam then the answer is yes..............in a 1330 cooper s engine with stage 3 head and twin hs4 carbs, it made really good power but drove like a dog!!
Edited by oltonlad, 12 May 2012 - 07:44 PM.
#4 Midas Mk1
Midas Mk1
  • 5,729 posts
  • Local Club: S.U.N.M.C
Posted 12 May 2012 - 07:46 PM
266 is an awesome cam!! :thumbsup:
#5 Wil_h
Wil_h
  • 3,244 posts
Posted 12 May 2012 - 07:53 PM
The 266 and the MG cam are not quite the same cam. The 266 has a larger overlap and slightly longer durations. The equavalent MG cam made by Kent is the KC500.
Both great cams for turbo use too.
#6 oltonlad
oltonlad
  • 2,401 posts
Posted 12 May 2012 - 08:45 PM
i know......some people on here keep saying that the MG cam and the 266 are both the same, if that was the case then why do kent make the KC500?.....its obvious that they are not the same at all........vaguely similar yes.......the same......no.
#7 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 13 May 2012 - 12:44 AM
iv heard there good for turbos but which is best for a 998 with your typical cooper 295 head and stage 1 kit, out of the kent 266 and the metro k500.
sorry about the hijack
#8 oltonlad
oltonlad
  • 2,401 posts
Posted 13 May 2012 - 07:07 AM
they are all good cams for a 998 with a 295 head, its really a case of which one of them is more available, a lot of the MG metro cams will be worn out now unless it is really low mileage, i would go for a kent 266 as i have one in my 1098 and its ace!
#9 valve bounce
valve bounce
  • 694 posts
Posted 13 May 2012 - 11:24 AM
i ran a mg metro cam in my 998 with a highly modded 295 head and all the other usually bells and whistles and it drove very nicely, power below 2500rpm was similar to a standard 850 but after this it would pull right until the valves started bouncing
in my 1275 i wanted alittle more so i went with the 276 and its a good cam it really works well for what i want, at current its in my daily that does a few auto tests, sprints, hill climbs and rallies, over the last 13months the engine have done 12000miles and probably 10 events for diffrent types. it get rev hard regular and still brings a smile to my face. 286 no thanks
#10 racingbob
racingbob
  • 3,061 posts
Posted 13 May 2012 - 11:54 AM
as i said the mg metro seemed to pick up more about 2750
putting foot down at 2000 in top
where does the 276 kick in doing the same test at 2000 revs in top
#11 valve bounce
valve bounce
  • 694 posts
Posted 13 May 2012 - 12:27 PM
im not 100% as i currently have a rev counter, but i do know that in top but teally starts to pull about 45mph in top with a 3.44 diff.
Edited by valve bounce, 13 May 2012 - 12:27 PM.
#12 86mayfair
86mayfair
  • 557 posts
Posted 13 May 2012 - 02:16 PM
In my 998 with standard everything 45mph reads as about 2500 rpm in 4th I think
#13 coopdog
coopdog
  • 4,506 posts
Posted 13 May 2012 - 05:31 PM
Depends on the final drive :)
#14 86mayfair
86mayfair
  • 557 posts
Posted 13 May 2012 - 05:33 PM
Oh I know, but I seeing as it isn't an "e" I think it should be 3.44? and I went out in it earlier and yes 45mph is 2500
#15 oltonlad
oltonlad
  • 2,401 posts
Posted 13 May 2012 - 05:51 PM
45mph is 2631rpm with 12" & 13" wheels and 3.44 diff.
45mph is 2728rpm with 10" wheels and 3.44 diff.
Edited by oltonlad, 13 May 2012 - 05:52 PM.
