Handbrake Problems
12 replies to this topic
#1 HafMan
HafMan
  • 383 posts
Posted 07 May 2012 - 02:51 PM
Ello ello everyone,
I've been having some trouble with my handbrake lately, It will engage but not hold the car on a hill.
So far I have jacked up the car and adjusted the rear drums and adjusted the handbrake but it hasnt changed.
Could someone post up instructions incase I have done it wrong?
The brakes seem fine driving.
The mini in question is a:
1997 Rover Mini Cooper 1.3
Any help is appreciated
#2 coopdog
coopdog
  • 4,506 posts
Posted 07 May 2012 - 02:56 PM
its a mini thing,
mine and most of my mates are crap
#3 charie t
charie t
  • 3,153 posts
Posted 07 May 2012 - 02:57 PM
it could be any number of things. quadrants seized, linkage seized, shoes worn, shoes contaminated
#4 charie t
charie t
  • 3,153 posts
Posted 07 May 2012 - 02:59 PM
its a mini thing,
No it is not, mine will hold the car with only 1 working.
If all is working the mini handbrake is good
#5 HafMan
HafMan
  • 383 posts
Posted 07 May 2012 - 03:00 PM
its a mini thing,
I hope not I live on a hill lol
How would i check the quadrants and linkage?
#6 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 07 May 2012 - 03:02 PM
give the shoes inside the drums a rub with some sand paper to take off the shiny edge and don't forget to give inside of the actual drum face a rub as well, then readjust and hey presto!
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 07 May 2012 - 03:03 PM
Also worth checking if it's working on both sides and the cable and quadrants are all correct
#8 HafMan
HafMan
  • 383 posts
Posted 07 May 2012 - 03:06 PM
Where are the quadrents located?
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 07 May 2012 - 03:11 PM
they're the bits the cable passes through on the rear subframe
#10 charie t
charie t
  • 3,153 posts
Posted 07 May 2012 - 03:27 PM
both should move easily and be free to return
#11 Samwise777
Samwise777
  • 221 posts
Posted 07 May 2012 - 05:26 PM
Yeah check shoes- might just be worn in which case new ones are needed. I wouldn't risk keeping the old ones if they're covered in crap, only 10 quid for a new pair anyway. Also when you put new shoes on make sure you smother everything else in high temp grease (seriously I learnt the hard way) :/ best of luck
#12 icklemini
icklemini
  • 2,982 posts
Posted 07 May 2012 - 05:40 PM
as charlie says... quadrants seized on one side... or the handbrake levers inside the drive have got stuck on one side.. so: you will put hand brake on, and it will only be working on one side...
jack up the back of the car.. with the handbrake on: try spinning the wheels...
#13 HafMan
HafMan
  • 383 posts
Posted 07 May 2012 - 05:56 PM
When I readjusted the drums both wheels where locking
