Spray Nozzle Sizes
Posted 25 April 2012 - 08:07 PM
if I can get my compressor up and running I am going to spray the mini on the drive, under a tent !! I will be using a thinned rustoleum as it is what I have got already !!
What nozzle size do I need for spraying, I see there are lots, 1.2mm 1.4mm. What difference do the sizes make to the spray job??
Thanks,
Graham
Posted 26 April 2012 - 12:35 PM
Obviously the thicker the paint the larger the tip. I have a 2.0mm tip which I bought for spraying polyester high build and even that isn't big enough.
Paul.
Edited by PaulColeman, 26 April 2012 - 12:36 PM.
Posted 26 April 2012 - 01:09 PM
Posted 26 April 2012 - 02:12 PM
can you get guns with changeable tips or are they a fixed item on the guns??
Graham
Posted 26 April 2012 - 03:16 PM
I bought a Sealy gun from http://www.justoffba...-Up-Sealey-S701 (superb service) as it was recommended in a practical classics magazine as best budget buy.
Came with a 1.8 and I bought a 1.5 set for the final (thinner) coats using celly.
The 1.5 was a kit with nozzle, air fan and I think maybe a needle as well. Spare kit was about a tenner if I recall correctly
Hope this helps
Steve
Posted 26 April 2012 - 07:46 PM
Paul.
Posted 26 April 2012 - 08:11 PM
You were correct Steve, £11.50 for the extra nozzle !!
Thanks fellas !!
Graham
Edited by grahama, 26 April 2012 - 08:12 PM.
Posted 26 April 2012 - 08:16 PM
Posted 27 April 2012 - 03:56 PM
Posted 27 April 2012 - 07:38 PM
My schultz gun turned up todat so getting closer !!
On the oiling front, I take it you don't oil a spray gun for the same reasons as water droplets from airline moisture ??
Graham
Edited by grahama, 27 April 2012 - 07:38 PM.
Posted 27 April 2012 - 07:51 PM
That would be a HUGELY bad idea!!
A 1.4 nozzle works well for most top coats and a 1.8 for primer.
Its best to have seperate guns for primer and top coat as the primer is abrasive and can damage the 'good' gun.
Posted 27 April 2012 - 08:31 PM
Posted 29 April 2012 - 03:32 PM
