Centre Speedo - What Are The Two Orange Lights?
13 replies to this topic
#1 mkw
mkw
  • 1,003 posts
Posted 13 April 2012 - 10:45 PM
Pretty simple, i presume oil pressure for one? or is it both?
#2 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 13 April 2012 - 10:47 PM
warning lights for your indicators (left and right)
#3 mkw
mkw
  • 1,003 posts
Posted 13 April 2012 - 10:48 PM
Surely thats the green light at the top? One light for both indicators?
#4 Mini Cheddars
Mini Cheddars
  • 1,209 posts
Posted 13 April 2012 - 10:50 PM
Haha I've wondered this before as well. My orange lights don't even have anything wired up to them. Just the backlight, green indicator and high beam.
#5 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 13 April 2012 - 10:52 PM
yeah, i just have the high beam and back light.
#6 mkw
mkw
  • 1,003 posts
Yeah, my orange "lights" have blanking caps over the holes. I've just fitted the centre dial and i've got one wire left, the oil pressure light so wondered whether to bother wiring it or not being as i've got a separate oil pressure gauge anyway.
#7 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 13 April 2012 - 11:00 PM
I think the idea is, if you wanted to, you could wire up respective indicator lamps.
I.e. when the green light flashes, it could be left or right, ive even left it on before and not been able to cancel it in a quick fluster because i didnt know what side it was. But yes, if you were to add extra wiring you could have either side flash for its respective indicator, ive done it on my dash in front of me.
#8 mkw
mkw
  • 1,003 posts
Posted 13 April 2012 - 11:02 PM
Is there a way to change the little coloured plastic bits then? To me green makes more sense to be an indicator colour
#9 mab01uk
mab01uk
  • 12,413 posts
Posted 13 April 2012 - 11:04 PM
They are for the oil pressure light when no gauge is fitted and the other is for oil filter warning light (ie. filter needs changing) only when the filter head has a spade terminal fitted for an electrical connection on some early models. The same centre speedo was also fitted to the Morris Minor 1000 so had to cover several options.
Edited by mab01uk, 13 April 2012 - 11:08 PM.
#10 mkw
mkw
  • 1,003 posts
Posted 13 April 2012 - 11:08 PM
Ah right, that makes more sense then! Cheers.
#11 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 13 April 2012 - 11:31 PM
:shy:
#12 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 13 April 2012 - 11:33 PM
I think that was the set up in the van and pick up originally.
#13 Down&Out
Down&Out
  • 4,851 posts
Posted 14 April 2012 - 12:28 AM
Both an oil pressure warning light and filter change light would be great, shame they never came with them wired in!
#14 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 20 April 2012 - 05:29 PM
They did for a while
