1293 Supercharged Blow Through Gt
Posted 13 April 2012 - 07:30 PM
Posted 13 April 2012 - 07:34 PM
also picked up some 4 pots from wales on monday along with some fibreglass seats for the car which weigh 2.5KG each
also test fitted my intercooler today as you can see in picture 1.
Posted 13 April 2012 - 07:37 PM
there isnt much left to do body wise really.
im currently just looking at dashes and it will be about ready for the engine which ive still got to put together....
i also had to buy this sticker when i seen it
Posted 13 April 2012 - 07:39 PM
one of the nuts is spinning in the heel board aswell where the subframe bolts up
going to start building the engine up next week. block went off to med wednesday to be bored and honed, ive ordered my cam followers and now all i need is center main strap and crank bearings.
Posted 13 April 2012 - 07:45 PM
basicly id like to push around the 170bananas mark out of the blow through set up and i think this is pretty acheivable looking at johnnys set up. ill be getting the kit from slark racing and ive been down there and spoke to neil about it and have the go ahead.
he never made a dummy kit so will be starting from scratch again on the pipe work, brackets and what not but he is going to build the kit on my car when its ready which should hopefully be around may time.
gearbox wise im running a straight cut box, straight cut drops, straight cut final drive and a sailsbury LSD
specialist components steel H rods
MED crank, reground, ni-temp, wedged and x drilled.
MED ultralite steel flywheel, backplate and paddle clutch
MED race head running 21cc
Edited by jameswildcooper, 13 March 2013 - 12:38 PM.
Posted 13 April 2012 - 07:51 PM
Posted 13 April 2012 - 08:24 PM
Posted 19 April 2012 - 05:35 PM
Edited by jameswildcooper, 13 March 2013 - 12:42 PM.
Posted 24 April 2012 - 06:25 PM
test fit of plate. sits lovely.
and a pic of it welded on with L brackets welded from the plate to the sill for extra support using the beam.... also did the same on the other side.
and a few other pics of the car :)
rear lights are bolted in properly now.
Posted 24 April 2012 - 09:24 PM
and now have these....
10x7 splits
Edited by jameswildcooper, 13 March 2013 - 12:43 PM.
Posted 25 April 2012 - 02:26 PM
and now have everything else for the bottom end to go together!
Edited by jameswildcooper, 13 March 2013 - 12:45 PM.
Posted 25 April 2012 - 06:14 PM
Edited by jameswildcooper, 13 March 2013 - 12:46 PM.
Posted 25 April 2012 - 07:14 PM
that way she is ready to go together tomoz
Edited by jameswildcooper, 13 March 2013 - 12:47 PM.
Posted 26 April 2012 - 10:19 AM
how much did all of that work to the crank cost you? im thinking about geting my crank re-worked, dont want it to go bang when i do some more upgrades.
alos, do you know if they had to polish the journals after ni-temping it?
Posted 26 April 2012 - 11:03 AM
not sure on the polishing to be honest.
