Edited by chrisxr2, 12 April 2012 - 04:06 PM.
Only Firing On 3 Cylinders?
Posted 12 April 2012 - 11:03 AM
Posted 12 April 2012 - 12:16 PM
I'm not sure how your spark tester works but still have a look at the plugs, it could still be fouled. Try swapping the plugs between cylinders and see if the fault moves with them. A compression test would also be worthwhile, but you may have answered your own question with that leaky gasket. You'd expect it to improve under load (open throttle) if it is an air leak.
Posted 12 April 2012 - 03:55 PM
Posted 12 April 2012 - 04:58 PM
Also try removing one HT lead from the plugs to see which cylinder is actually dead or poor, if you take the first lead off and it runs worse then you know that cylinder is working, try the next then the next, only removing one lead at a time. If you take a lead off and the engine stays the same then you know that is the cylinder that is at fault.
Careful not to get a shock off the lead whilst your doing this. I am not responsible for any potential injuries
Posted 12 April 2012 - 05:32 PM
As mentioned above: probably plugs/ignition, could be headgasket as well...
Do a compressiontest.
Posted 12 April 2012 - 06:29 PM
Posted 12 April 2012 - 06:47 PM
1.Rough running, which yours is,
2.Loosing water, check the coolant level,
3.Pressurising the cooling system, so after a short run if you remove the rad cap it would throw most of its coolant out (please dont burn yourself, I wont be held responsible!!!)
4. Overheating,
5. Yellowy/grey sludge under the oil cap and in the rocker cover.
Most garages can perform a 'sniff' test to determine if the head gasket has blown too.
And changing the head gasket aint hard IF your a competent home mechanic, but get it diagnosed first, it'll be a lot cheaper.
Posted 12 April 2012 - 06:51 PM
Posted 12 April 2012 - 07:53 PM
99% of garages will have a compression tester dude. If it was a head gasket you would have at least one or more of the following symptoms:
4. Overheating,
For point 3, start with cold engine, bonnet oen & radiator cap off. If the water in the radiator suddenly jumps out, then the head gasket is not well. Might take a while until the thermostat opens.
If it is the head gasket, be sure to get a qualty replacement - I had one with "front" and "top" stamped into it wrongly, so only one was correct... Naturslly, it blew after only a month or so.
Edited by Blatherskite, 12 April 2012 - 07:55 PM.
Posted 12 April 2012 - 08:13 PM
