Ngk Bp6Es Gap Size For Mini 1000
Posted 11 April 2012 - 03:13 PM
there seems to be alot of mixed ideas on the internet about what the gap size for a NGK BP6ES spark plug should be for a mini 1000?
hope someone can shed some light
cheers
Posted 11 April 2012 - 03:26 PM
Gap incresing is necessary only if you carried igniton mods like hi voltage coil and electronic ignition, so you can benefit of a stronger spark though the wider gap.
Posted 11 April 2012 - 03:36 PM
Posted 11 April 2012 - 04:20 PM
Always check the gap. NGK does sell some pre-gapped plugs but they usually have a suffix after the 5-digit part number to indicate the gap.
With a points ignition system, start with a spark plug gap of 0.025"
Posted 11 April 2012 - 05:16 PM
electronic i have on mine 32 thou
Posted 11 April 2012 - 06:46 PM
Posted 11 April 2012 - 06:48 PM
Posted 12 April 2012 - 01:03 PM
Whats that in metric for us younger folk??
0.8 ish??
If you are into Minis then you must be into inch dimensions really. You also need Imperial size spanners and sockets as metric ones are simply not right for the job.
Posted 12 April 2012 - 01:06 PM
Whats that in metric for us younger folk??0.8 ish??
Unless you have an 86 like me, and you need both!!! It's so annoying
Posted 12 April 2012 - 01:25 PM
i completly messed up about 6 months ago
set tappets with metric 15 thou was 15 metric
went out for a spin seemed ok but something was bugging me
and telling me to check my tappets again !!
and low and behold. good job only went for shortish spin
Posted 12 April 2012 - 09:49 PM
being old at not into metric as far as tappet setting etc
Been there, done that.
Posted 12 April 2012 - 09:57 PM
Later Minis have a lot of metric stuff on them so it's best to have both metric and imperial tools to hand.
0.8 ish??
25 thou = 0.64mm
32 thou = 0.81mm
