I Need New Underware!
50 replies to this topic
#31 valve bounce
valve bounce
  • 694 posts
Posted 10 April 2012 - 09:17 PM
I wonder if anyone bothers to grease (along with the top and rear arms) and check their minis balljoints every 3k or 3months anymore?
i do, i check the car over fully and do a full grease every 3 months, i usually do the oil/filter and grease clean and adjust the rear brakes at the same time. i always find if i maintain it, it brakes down less. 1 brake down in 12months (8500miles) is quite good in my book
#32 jaydee
jaydee
  • 8,565 posts
Posted 10 April 2012 - 09:28 PM
I'm curious too, because i guess even the MOT tester havent checked..
#33 jaydee
jaydee
  • 8,565 posts
Posted 10 April 2012 - 09:31 PM
i finally get it stopped, get out walk to the front left to find this.........................................................
Was the car lowered?
#34 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 10 April 2012 - 09:47 PM
My car failed mot on a ball joint last time they advised to grease it up. this is not the correct way to fix the play. i have since replaced all 4 and lapped them in correctly as described in the mini addicts video. i am always checking for play and greasing all the points around the car as im scared this will happen! >_<
glad you came out of it ok! and that your body work hasnt been damaged
#35 thebullet
thebullet
  • 1,337 posts
It makes me think everytime I hear about one of these :/
#36 joshspragg
joshspragg
  • 984 posts
  • Local Club: M4 minis
Posted 10 April 2012 - 10:30 PM
this is my biggest fear. i was going down a massive hill doing 60 and i thought if my ball joint snaps i'm screwed! get them greased soon i think :)
#37 Mrt88
Mrt88
  • 300 posts
Posted 11 April 2012 - 11:43 AM
So some good news for everyone, and bad news for me.
Closer inspection this morning now its on the lift, it wasn't the ball joint that caused the failure. it was a cracked hub (upright), when that failed it then took the ball joint with it. as its the first thing that you can obviously see then we thought it was that.
so looks like new hub, ball joint, possibly track rod ends etc. nothing that isn't fixable thankfully.
Edited by Mrt88, 11 April 2012 - 11:44 AM.
#38 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 11 April 2012 - 12:08 PM
Happened to me too. Mine was a cracked hub also. It wrote the lower ball joint off in the process. Luckily I was doing about 15mph as I was about to pull into my driveway!
#39 paul_s
paul_s
  • 415 posts
Posted 11 April 2012 - 01:40 PM
I'm starting to get a bit nervous now - mine failed at the MOT because one of the joints had too much play. They shimmed it apparently, I'm guessing this might be no better than just packing it with grease?
Glad you're ok though and the car's not seriously damaged - a lucky escape! Hope you get it back on the road soon
#40 Mrt88
Mrt88
  • 300 posts
Posted 11 April 2012 - 03:23 PM
Thanks buddy, she'll be done by tomorrow. most of it is back together.
#41 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 11 April 2012 - 03:24 PM
Ball joints breaking seems to be happening a lot lately, think I may take mine to get checked out :ohno:
i was just thinking the same LOL
#42 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 11 April 2012 - 03:26 PM
Think I may take it to mintro on Tuesday and leave it there for them to have a look while I'm at college :lol:
#43 HafMan
HafMan
  • 383 posts
Posted 11 April 2012 - 10:18 PM
Well after seeing all these occurences happening latley I think I may check mine.
Also what grease should be used on the mini?
#44 joshspragg
joshspragg
  • 984 posts
Posted 11 April 2012 - 10:25 PM
lol now you've scared us all that not only our ball joints are gonna snap but so are our hubs. :( i dont want to drive fast anymore :( at least now you know it wont happen again with the new parts (fingers crossed)
#45 minimissionary
minimissionary
  • 999 posts
  • Local Club: Fylde Mini Club
Posted 11 April 2012 - 10:27 PM
Did I just hear someone say "It'll never happen to me." :ph34r:
