Help! Key Will Not Turn In Ignition
18 replies to this topic
#16 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 11 April 2012 - 06:33 AM
The ignition lock is not interlocked with the shifter or anything else in a Mini
Dan, what about the steering lock?
sounds like steering lock to me. without touching the key does the steering wheel move at all? if it doesnt your lock is on and turning the key to the first position while moving the wheel should free it
GummoMarx - have you tried Mr Stocky's suggestion?
long shot but if you can see the outer casing, try giving it a few taps while trying turn the key, may shock it free
Please don't try this until experimenting with the steering lock
Edited by L400RAS, 11 April 2012 - 06:34 AM.
#17 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 April 2012 - 08:10 AM
Steering lock, ignition lock, same thing!
The OP states he tried to release the pressure on the steering lock by turning the wheel in the opening post. Can we move on from that now? I think it's been suggested, and replied to, enough times. Tapping the lock is a good idea to get the tumblers moving.
#18 hunterg30
hunterg30
  • 349 posts
Posted 11 April 2012 - 03:26 PM
have you shorted out any of the wiring, take the switch off the steering lock ,then try turning key.if it fully turns to where it should then its the switch. or drill the heads off the bolts holding the lock on, check locking pin and also the cut out in steering column for burring. you will need 2 new shear bolts to do this
Edited by hunterg30, 11 April 2012 - 03:28 PM.
#19 Brams96
Brams96
  • 2,308 posts
Posted 11 April 2012 - 04:33 PM
Sounds like a rover problem. Check the last pic of this page
