Idling So Low It Stalls
Posted 08 April 2012 - 07:01 PM
New belt is on, turns out the old belt was the wrong belt, it lasted less than 300 miles!
Today I took the car for its first drive since the belt snapped. I think it feels less responsive and it sounds almost muffled, perhaps a little hesitant. Also it quickly started idling at such low revs that it stalls. What do you think I've done and how can I fix it? It drives OK overall, just stalls whenever the engine isn't being used.
I apologise if the answer is easy to find by searching but I have a project deadline for tomorrow and simply don't have the time to go looking. At some point between now and tomorrow afternoon I have to finish my project, drive back to Oxford (after sorting whatever might be wrong) and hand it in!
Posted 08 April 2012 - 07:03 PM
Posted 08 April 2012 - 07:06 PM
Posted 08 April 2012 - 07:09 PM
Serious overheat can lead to poor ring seal resulting in excessive crankcase pressures also.
If the only thing that happened between it being OK and it running crap was the belt failure and overheat, you need to check for head gasket failure.
Edited by Sprocket, 08 April 2012 - 07:11 PM.
Posted 08 April 2012 - 07:10 PM
Posted 08 April 2012 - 07:50 PM
this did happen to mine you want to adjust the idle. also if neccesary use some choke as the engines probably to cold
I don't have a choke, as it says above I've got a 96 SPI, incidentally it was fine when cold, the problem developed after the engine warmed up...
Overheat?>>Head gasket failure? carry out a compression test on a warm engine. Check the coolant level also.
How do you do a compression test? Not done that before, do I need special tools? Do you check for head gasket failure by doing the compression test or some other way? The coolant had almost all escaped but I topped it up, should have checked it was all still there after my drive today but the engine temperature was completely normal.
What does it run like when you're going?
It seems to run OK, something about it seems a little muffled/hesitant but I might be imagining that.
Posted 09 April 2012 - 01:27 PM
