So you have set the serial com port within options?
Another Spi Emissions Test Failure
#31
Posted 04 August 2020 - 08:12 PM
#32
Posted 04 August 2020 - 08:36 PM
On the other hand, if you can`t get mems-rosco running.You have found readmems already.You could switch to dos mode and run readmems.This command :readmems.exe com(your com port) read 500 >logfile.txt will write a logfile what you can open under readlog in mems-rosco.
This command: readmems.exe com x interactive 0xAF will reset your ecu.
Other commands are shown if you type only readmems!
#33
Posted 04 August 2020 - 08:52 PM
Thanks genpop. I will have a go at dos mode tomorrow. (never thought i'd be using DOS again)
#34
Posted 04 September 2020 - 05:57 AM
Did you find a solution? What was the fault?
