Roller Painting With Hammerite
#121
Posted 13 August 2012 - 09:32 AM
#122
Posted 13 August 2012 - 06:31 PM
Also remembered that I haven't primed the bonned or boot lid yet... D'oh!
#123
Posted 13 August 2012 - 09:24 PM
Primered:
Sanded:
First coat on the roof:
some streakyness on first coat
Some bubbles right after painting
Bubbles mostly popped after a couple of minutes
After second coat
once it was touch dry
Going to leave it overnight, to dry properly and hopefully get some time to sand it back slightly tomorrow followed by another coat. Some progress at last!
Edited by jeebz, 13 August 2012 - 09:25 PM.
#124
Posted 13 August 2012 - 10:39 PM
Are you using rusto or dulux? How was the drying time? I've got one bit of smoothing left then ready to begin but the tin says 16hour between coats!
#125
Posted 13 August 2012 - 10:55 PM
Leaving it overnight now and going to be out until 2 tomorrow so that should give it plenty of time to dry. If I wake up early I may risk it though, even though it will only be around 12 hours. Still need to find a colour for the body, umming and arring over grey, cream or dark blue. The arches and bumpers may get a going over tomorrow in the black as well.
Not sure if I should paint the inside as well as I am planning to carpet everything anyway.
#126
Posted 13 August 2012 - 11:00 PM
I'd say go... anything but dark blue
I've got to shape my arches to fit yet, that and fit the spacers so I know how wide to trim them... Busy days
My inside is already done, I did that when I fitted the carpets / seats / sound damping.
#127
Posted 13 August 2012 - 11:10 PM
#128
Posted 13 August 2012 - 11:22 PM
I went the budget route, which is to say I didn't go with brand names. I did however go maybe a touch OTT with it, as I had some left over after the first layer I doubled up on the inside of the arches and front bulkhead where most of the sound came from.
Roughly it was 2 x flashing tape rolls from screwfix @ about £15 each.
2m² of 10mm thick closed cell foam for the floors, inner arch edge, bulkhead.
2m² of 6mm thick closed cell foam for other areas, doors, seat backs, roof, boot.
And some carpet underlay.
It's never cold in the car, that's for sure!
Some pics:
http://www.theminifo...r/#entry2562729
#129
Posted 13 August 2012 - 11:31 PM
#130
Posted 13 August 2012 - 11:33 PM
There's some adjustments to be made on mine but as a first attempt it's okay.
Just wait until you see the next one!
What's the plan for yours?
#131
Posted 13 August 2012 - 11:50 PM
The aim is to keep the basic mini shape and identity, but try and squeeze in a few creature comforts as well. A-series will be replaced at some point along the line as well.
#132
Posted 13 August 2012 - 11:54 PM
Same philosophy as I had, intrinsically Mini but a little more up to date too.
Need some pics of the progress I reckon
#133
Posted 13 August 2012 - 11:56 PM
#134
Posted 14 August 2012 - 03:42 PM
I think ill start a thread once the paint is on. All the proper jobs need doing then like wiring and sticking in an engine. Good thing about being completely stripped is that I can do what I want with it.
Be sure to post a link for us.
Sorry ive only just broken silence but have had nothing to say
crowns gloss black for wood & metal paint (foam rolled) just to see what results i would get.
Will get pictures up some time soon.
Regards
Clifford
#135
Posted 14 August 2012 - 09:29 PM
Sorry no pics today, I did take some but they just look the same as yesterday only with less streaks, but with run lines instead. Used a less loaded roller today to see if that made a difference.
