Roller Painting With Hammerite
227 replies to this topic
#151 Big Man
Big Man
    Put your trousers on---You're Nicked!!
  • 1,002 posts
Posted 19 August 2012 - 11:49 AM
I used my brush with 100% paint and to be honest there is little to no difference with 50 /50 maybe I did not stir it up enough before getting it out of the tin! !!! or its just the cheap paint however I am more than pleased with the rollered result as its coming on with a deep lustre and thats before sand and polish on a 50 / 50 mix on the bonnet and boot.
I used a scouring pad the one with a sponge on first then did the wire wool.
Damn hot today so BM says make sure you have plenty of water on hand Skorchio !!!!
Im working in my wooden garage with no windows (Boarded up) and it is like a sauna ...well sort of just not naked!! yeah okay sorry for the bad mental images lol
BM
#152 Big Man
Big Man
  • 1,002 posts
Posted 19 August 2012 - 04:09 PM
Well i used my orbital sander with 1200g wet roof loads of water with soap and guess what....yep burnt through the paint in two patches....happy i am not.
despite the burning through in two patches the finish i got was ok but not as good as using the following ...00g and that scouring foam pad....get the same results using a 400g (ish) sanding block the dimples just melt away!
right Im trying to cut corners and do things too quick....I must be patient. So I cleaned the roof up and put another coat of black on slightly thicker as needed to cover the patches where the polisher sanded through.
Thats it other than a slight bit of sanding and body prepping on the bottom of the door and rear quater panel.
I may end up re doing my whole roof, it should if I take my time cut down getting rid of the tiny tiny dimples (not orange peel like) just tiny imperfections ...maybe im being a bit of a perfectionist ! either way I do not get the dimples using my thinned gloss orange so it may be the black paint i am using and it is not fit for purpose....(remember I bought non drip and thin it 50/50) dont get any dimples in the orange at 50/50
Either way will finsih off the roof prob nxt week now as up north for few days so should give the last coat a good curing time.
Orange is still looking good the only blemishes being dust particles but hey such is life !
Also did a bit of body work on the herald and tried to sort my running issues out.....still cant find my haynes for IT !!!
For those who have been working on their minis today hope all went well !
BM
#153 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 19 August 2012 - 04:37 PM
Have been? Still am! Flatting back is going okay for the most part but had a couple of similar issues to you, I suspect it was a little humid when I applied the paint and coupled with the slightly thick mix it hasn't totally cured in a fee places, so the 400grit pulled it off the primer, no more than A few inches across each but frustrating all the same.
That and like you I find myself flatting back far to much, pushing for a perfect finish.
Also tried a bunch of different scourers but couldn't get a good match, long slow 400grit it is...
Only a door, A panel and wing to go. Then a fresh thin coat of colour - assuming It's not dark :P
#154 jeebz
jeebz
  • 155 posts
Posted 20 August 2012 - 11:08 AM
Just realised the paint I had been waiting for the last week or so wasn't ordered, so I've been waiting around in vain. Might actually walk to a shop and do it the old fashioned way.
#155 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 20 August 2012 - 03:27 PM
D'oh! I've done that before, nothing worse than an angry phonecall that culminates in you looking a bit of a tit :P
If It's any consolation, I had to remove near enough a whole wing of paint plus 1 patch on pretty much every panel due to the paint not adhering in places, think it was moisture and over enthusiastic sanding.
2nd coat just went on, now to paint the door jams and sand the the boot while it dries.
#156 Big Man
Big Man
  • 1,002 posts
Posted 20 August 2012 - 05:24 PM
Looking forward to getting back and hitting the orange again after being fed up with the black roof..... may do the roof again this time taking a few chill pills so I dont try to be the perfectionist and remembering this is not a £1000 spray job!!!
Really annoying when you cut thorugh paint though as not sure how it will cover up etc......no short cuts for me next time I will listen to what others have done ! Also when using wire wool the mess it leaves behind is monumental !!!
I bought my paint the old fashioned way....easier to ask for discount lol !! tight Geordie again lol
Bm
#157 jeebz
jeebz
  • 155 posts
Posted 20 August 2012 - 05:46 PM
Well the shop didn't have the colour I wanted, or enough in a colour that would have done. Instead bought a load of insulation for the inside the car and did that instead today. Got that on discount so it was worth the 100 metre walk.
#158 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 20 August 2012 - 07:06 PM
After a frustrating start to the day, namely pulling the paint off most of the wing. I went about some serious scrubbing of the rest of the paintwork to make sure it was free of contaminents this time and dry!
Back to 50:50 mix or there abouts, well squeezed roller and lots of rolling the paint about.
Worked well, at least it seemed to have after 4 hours. I decided not to chance putting another coat on and left it for the night, got another coat on most of the black parts too so the glass can go back in once that's dry (and I buy a windscreen...).
It's pretty apparent where the paint had to be cleaned off but I'm hoping / guessing / praying that as the layers build that should blend away nicely.
Todays offering:
#159 Big Man
Big Man
  • 1,002 posts
Posted 20 August 2012 - 07:46 PM
Looking really really good there Skortchio and think that it will cover really well...good colour choice too by the way. I leave it overnight before applying second coat only because im not in a mega hurry. Is this done in your Gazebo ?
Had the same issues on my boot lid as was not prepped properly and had a few large pinholes where the paint had not taken. Just sanded it back and started again.
Really impressed witht he work done buddy
BM
#160 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 20 August 2012 - 07:53 PM
:shy: Cheers dude, all your helpful advice!
Yep, was done in the gazebo. It's holding up okay but the driveway is pretty sheltered anyway, mostly it's keeping the leaves off.
Tomorrow I'll give it light brush over with the scourer or high grit just to take the dust off and give it another go, last night I was ready to strip it all off and go buy some 2k. Given I've got all the equipment the only reason I didn't spray it initially was not having somewhere to do it but I have the gazebo now.
Trouble is, I hate giving up on something so want to see how this turns out. My only concern is the durability of it, but time will tell on that one.
Oh, that reminds me I found the thread with the coach builder referencing Dulux last night.
About half way down:
http://retrorides.pr...&page=1#1485548
#161 Big Man
Big Man
  • 1,002 posts
Posted 21 August 2012 - 08:57 AM
A very inspirational thread on retrorides....however in years to come ours will be the guide lol !
One issue I see coming up is having roller painted (happy I can do that to a reasonable standard) is getting a similar finish on areas where the roller will not reach.
#162 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 21 August 2012 - 10:41 AM
Foam brush matey, I've done the top half of the car in it so far and it's no half bad.
I was going to just cut in around the edges, seams etc but then figured it's only really the scuttle and rear quarters with any amount of surface.
#163 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 21 August 2012 - 05:15 PM
After waking up with a mental headache and feeling generally rubbish, I decided that I'd have a day off staring at paintwork...
Yeah, like that worked!
Coat number 3 on now, it was actually nice to flat back - not a proper flatting, from some more reading on roller threads it seems that bug & run removal is more than enough between coats and then something a bit more careful every 3rd (ish).
So 30mins to take off the dust and a single run, then a whip round with the roller which is also getting faster too.
The patches I had to sand back to primer are darkening nicely so that's reassuring and the first coat on the bonnet went on too.
Not bad for a couple of hours. Suppose I should start putting the rest of the car back together now...
#164 Big Man
Big Man
  • 1,002 posts
Posted 21 August 2012 - 06:46 PM
Looking good dude! are you doing the whole car in the blue?
#165 Big Man
Big Man
  • 1,002 posts
Posted 21 August 2012 - 06:47 PM
Oi Jeebz has your paint arrived yet :shifty:
