Another Camper Project - Bedford Cf - Warning Pic Heavy / Rot Heavy
60 replies to this topic
#1 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 02 April 2012 - 07:29 PM
Hi All,
Well the bedford has been in the garage getting its new engine fitted for..... 6 MONTHS! Whilst waiting I decided that the sensible thing to do would be to buy another camper as a donor vehicle ready for the rebuild. When I found one on eBay it was a little small for us to actually camp in but the panels looked in good condition so I bought it anyway.
When it arrived the wife and daughter fell in love with it straight away (which they will later regret when they see the state of it) so we have decided to rebuild this one first to hopefully get away in this summer and next summer whilst I 'seriously' rebuild the other one.
Here she is arriving at the unit. I already have a bedford bambi and an Austin mini in here so space is getting tight now - and the big camper isn't even here yet.
More pics to follow shortly when they upload.
Edited by maryquant, 19 April 2012 - 07:26 PM.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 April 2012 - 07:59 PM
if you think that's small what do you think of our old VW camper
#3 Criptix
Criptix
  • 75 posts
Posted 02 April 2012 - 08:00 PM
Cant wait to see updates on this, what are planning to do with it
#4 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 08:09 PM
@bungle - I love yours, and unlike mine yours is being repaired properly by someone with skills :P I have to actually bribe my assistant so bought a Bedford Bambi for him to restore while helping with mine. Now the bambi really is tiny.
@criptix - This one will have the rot removed, be relined, re-sealed and then have new cabinetry etc installed. The vehicle itself is in pretty good shape with minimal rust etc. The other bedford we have will be much bigger - extended by a few feet and be a complete custom back :P
Photobucket is soooooo slow.
#5 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:22 PM
On first inspection everything seemed manageable...
Not much rot above cab.
Start to see the area where the majority of the wet stuff got in...
It was clear by this time that the wardrobe would need to come out...
And this cupboard...
#6 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:25 PM
Some damp further along the wall... not a good sign
Cupboard doors off and its really starting to show...
These cupboards etc had been installed to a fresh piece of timber which had clearly been attached to the rotten stuff behind, so a larger job than I first expected.
We removed the worktop, and utilities - the gas is all coming out anyway as I hate the stuff, and the electrics are being replaced and wired in with RCD trips :P
Proof my assistant can work...
Organised chaos
#7 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:29 PM
The corner really is damp, the construction is basically exterior metal, with polystyrene glued to it, and then a chipboard glued to that - its a nightmare to get off and is very very damp (I could squeeze water out of the polystyrene)
Paloma water heater ready to go up on eBay, along with the fridge, cooker, sink/grill etc I should be able to get a couple of hundred toward rebuilding.
The nice headlining was covering the old damp headlining so unfortunately that will be removed too
More destruction ensues.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 April 2012 - 09:30 PM
isn't he just peeing in the corner ?
#9 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:34 PM
The over cab box is fibreglass - so shouldn't be any problem there, but it is attached to the van with screws into rotten wood - ill take it off probably and recon all the window seals before refitting.
No fuse wire left in tool box so will replace this with RCD trip board
More stuff for eBay (poor mary in the background)
Im going to have to find a better way of separating these layers without damaging the exterior aluminium
Damp goes right to the back of the van, this whole wall is now getting redone.
Two batteries wired in parallel - will replace this for a proper leisure battery with split charge system
#10 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:35 PM
So 5 hours into the rebuild and we've gone from a semi-useable camper to this
Will get some more done tomorrow evening when I have some tools at the unit.
#11 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:36 PM
Nah - if his past work ethos is anything to go by then he is probably just trying to make it look like he is....
#12 maryquant
maryquant
  • 932 posts
Posted 02 April 2012 - 09:53 PM
This gives a good comparison between the size of both campers, the one in this project thread is this big...
The one that should be here in a few weeks is this big...
And to that I will be adding probably another 2-3 foot in length.
#13 Criptix
Criptix
  • 75 posts
Posted 03 April 2012 - 01:40 AM
Well it looks like you got your work cut out for you, good luck
#14 maryquant
maryquant
  • 932 posts
Posted 04 April 2012 - 11:01 PM
MAJOR update today and its only day 2 of the rebuild...
Whilst the photos update to photo bucket lets just say that the rebuild has taken a severe turn, the damp was a lot worse and a lot more 'everywhere' than I first imagined. To make matters worse we discovered the van had a little secret which has meant even more bodges/work to do.
Pics in a bit...
We started to see how easily the polystyrene would come off - whoever stuck this section down really used some strong stuff.
This proved exceedingly difficult, which was odd because some of the polystyrene practically fell off - just these panels were sticking
Edited by maryquant, 04 April 2012 - 11:07 PM.
#15 maryquant
maryquant
  • 932 posts
Posted 04 April 2012 - 11:11 PM
Starting to see evidence of a poor repair...
