New Build, All The Gear No Idea.
197 replies to this topic
#76 mrthumb
mrthumb
  • 144 posts
Posted 22 August 2012 - 10:03 PM
right 2 tins of GRAVITEX ordered :)
might not have to worry about **** loads of sound proofing now.
it sets harder than other stuff and is overpaintable.
Edited by mrthumb, 06 September 2012 - 09:45 PM.
#77 mrthumb
mrthumb
  • 144 posts
Posted 04 September 2012 - 08:19 PM
ok time for a update... been busy!
first off reinforcing plates installed, bolted and forgotten about..
Attached File  reinforcing2.jpg   77.16K   18 downloadsAttached File  reinforcing.jpg   85.55K   17 downloads
Next is the fuel tank...welded up, leak tested, mounted and installed and ready to be plummed in. I also used a motocross breather valve and pressed it into the filler cap. yea my mini will stink of petrol. but i wont to keep the original smell. ^^
Attached File  fueltankbottom.jpg   59.8K   22 downloadsAttached File  fueltankmounted2.jpg   45.62K   13 downloads
Attached File  fueltank.jpg   68.76K   15 downloadsAttached File  fuelbreather.jpg   35.8K   14 downloadsAttached File  fuelcellmounmted.jpg   46.19K   16 downloads
Gear linkages fabricated, installed and a plate to cover up the huge hole installed. it changes gear perfectley and is at the correct height, and feels about right for me.
Attached File  gearstickplate.jpg   69.8K   14 downloads
more welding... I just was not happy with the state of the door hinge plates.. the iron to iron oxide ratio was way too high for my likeing. It also gave me a oppertunity to fill the sills with cavity wax...
Attached File  hingewelding2.jpg   48.43K   20 downloadsAttached File  hingewelding.jpg   37.98K   18 downloads
the heater matrix is more a less plummed in now with a nob installed to turn the heat on and off..
Attached File  interior.jpg   67.85K   33 downloadsAttached File  drivingposition.jpg   66.26K   32 downloads
fuel lines connected to engine.
Attached File  fuellines4.jpg   67.98K   47 downloads
throttle cable plummed in, setup and works perfectley :)
Attached File  throttlecable.jpg   62.05K   37 downloadsAttached File  throttlecable2.jpg   82.48K   25 downloads
Final look before bed.
Attached File  gettingthere..jpg   85.34K   76 downloads
#78 Rhys
Rhys
  • 898 posts
Posted 06 September 2012 - 01:09 PM
Beautiful work, you're doing a great job.
#79 mrthumb
mrthumb
  • 144 posts
Posted 07 September 2012 - 09:23 PM
thanks buddy :shades:
got the fuel tank sprayed red like the rocker cover... will get some pics up soon.
#80 mrthumb
mrthumb
  • 144 posts
Posted 08 September 2012 - 06:50 PM
ok got some more done today...
got the heater matrix and brake lines working.
Attached File  plummedin.jpg   82.29K   33 downloads
next i had to fabricate the exhaust. i used a old cat and cut the flange off to make for the flange on the swan neck.
Attached File  exhaust3.jpg   67.46K   49 downloads
all welded up. Attached File  exhaust2.jpg   59.48K   57 downloads
just waiting on another section of exhaust to finish the job.Attached File  exhaust.jpg   39.56K   26 downloads
Edited by mrthumb, 08 September 2012 - 07:21 PM.
#81 thelegg
thelegg
  • 608 posts
Posted 09 September 2012 - 05:24 PM
Your fabrication work is amazing
#82 mrthumb
mrthumb
  • 144 posts
Posted 10 September 2012 - 01:00 PM
Thanks :) would be nice to do this as my main job.
#83 mrthumb
mrthumb
  • 144 posts
Posted 10 September 2012 - 07:25 PM
2 updateds today...
painted the fuel tank flame red.
Attached File  fueltankpainted2.jpg   52.5K   13 downloadsAttached File  fueltankpainted.jpg   61.86K   11 downloads
Also modified the radiator so that the standard hoses fitted without kinking...
Attached File  radiator2.jpg   52.68K   24 downloadsAttached File  radiator1.jpg   61.41K   35 downloads
if anyones thinking of doing this yourself i have to point out that its a very trickey thing to attempt...
the slithers that carry the water are solderd together. so when the aluminium reaches a certain tempature the lead/solder will melt away. so i had to weld a little bit, then dunk it in water. then weld some more... this made it hard to get a tidy weld as it got contaminated by the water over and over. but it appears to hold some pressure ok which i applied with the airline.
#84 Jamie_hail
Jamie_hail
  • 555 posts
Posted 11 September 2012 - 12:29 AM
All the gear, no idea... Seriously, you have to be one of the most talented out of all of us who have done honda builds!
#85 mrthumb
mrthumb
  • 144 posts
Posted 11 September 2012 - 08:55 PM
wow thanks. i mean i really knew nothing about this. i didnt know what a top arm from a bottom arm was, or how to bleed or run brake lines, what a drive shaft looked like, what a CV joint was.... my friend has been helping make decisions and working on bits im unsure off. and the internet has been crucial too in helping me.
this is the first mini i ever owned, i only braught it because i split from my girlfriend and i needed somthing else to play with in the evenings ^^
and was all a big mystery to me to begin with. but as things have unraveled themselfs i find myself applying what equipment i have in best possible way... "oh i can weld that, bend this, fabricate that". I just get ideas, and follow them up, yea i bugger things up sometimes, but a man who makes no mistakes never makes anything at all iv been told.
another thing that makes me want to do a good job, is that iv invested quite alot in this allready far more than i ever planned. and i want to get my money back one day which means having nothing for someone to pick up on. i hope others look at this use my ideas, and get the confidence to have a go themselfs.
and remember kids....
Attached File  379v.jpg   43.58K   14 downloads
#86 Jamie_hail
Jamie_hail
  • 555 posts
Posted 12 September 2012 - 04:19 PM
Thats exactly how I started... I'd only ever worked on motorbikes, complete newbie to cars and multi cylinder engines! Split from my ex, and needed something to take my mind off stuff/pass the boring evenings! Least I cant catch anything from the car ;)
Best of luck to you - it's already taking shape nicely!
#87 johny:)
johny:)
  • 311 posts
Posted 12 September 2012 - 05:23 PM
I love that last pick about crafting a mini vtec :) great work on your build as well really impressed keep it up and you will be done in no time
#88 mrthumb
mrthumb
  • 144 posts
Posted 12 September 2012 - 07:39 PM
thanks for the encuragement lads... yea thats my first ever internet meme :) yea the only STD a mini can carry is tetanus :)
iv been hard at work on the exhaust again tonight. due to clearance issues and also if the exhaust got banged the stress would go up into the manifold which is somthing i dont want to risk. so iv had to replace my finley crafted swan neck bend with some flexie tube. more pictures to come tomorrow!
#89 mrthumb
mrthumb
  • 144 posts
Posted 13 September 2012 - 05:18 PM
heres somthing for ya.. my switches for my dash.. i didnt want the same old race car style switches. i wanted somthing that would make the car unique... so i dediced to get some ww2 aircraft switches and maybe some guages? prehaps a tempature sensor if i can find a working thermocouple for them... anyway heres the switches. what shall i use them for...Attached File  switches.jpg   55.93K   48 downloads
Edited by mrthumb, 13 September 2012 - 05:18 PM.
#90 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 13 September 2012 - 05:44 PM
Just checking here as I can't see clearly in the picture, that braided line coming out the bottom of the fuel pressure regulator, does this go back to your fuel tank as thats your fuel return line, can't see where it wanders off to in the picture thats all
This is coming along very nice indeed, keep at it
