New Build, All The Gear No Idea.
197 replies to this topic
#46 mrthumb
mrthumb
  • 144 posts
Posted 10 August 2012 - 08:48 PM
thanks, getting there slowley... looking forward to it being rolling again :)
#47 mrthumb
mrthumb
  • 144 posts
Posted 11 August 2012 - 02:36 PM
ok guys i got the new hubs drilled out and new studs put though. the position seems perfect.
Attached File  newpcd.jpg   81.58K   31 downloadsAttached File  newpcd2.jpg   67.45K   31 downloads
i then had to enlongate the holes in the brake disks to make them fit. about 50 strokes with the file on each hole did it.
Attached File  newpcdbrakesfile.jpg   66.97K   23 downloadsAttached File  newpcdbrakes.jpg   66.71K   29 downloads
and finally we are on 4 wheels again!
Attached File  onwheels.jpg   93.67K   56 downloads
had new bearings fitted in the hubs and the play in them is awfull... probably about 10 mm and they slide in and out quite alot. is this because i had not got the drive shafts connected yet? thanks
i think the next job will be to create some spigot rings or adapters so that its not relying on the studs to center it.
Edited by mrthumb, 11 August 2012 - 02:38 PM.
#48 Rhys
Rhys
  • 898 posts
Posted 11 August 2012 - 03:13 PM
Where is the play?
#49 mrthumb
mrthumb
  • 144 posts
Posted 11 August 2012 - 03:40 PM
heres a video. they were a little tighter when i first had the bearings pushed in. but i dont think its suppost to be this bad..
http://www.youtube.c...bed/xpRRsZyQiQU
should i take these back to the place where i had them done?
Edited by mrthumb, 11 August 2012 - 05:27 PM.
#50 Rhys
Rhys
  • 898 posts
Posted 11 August 2012 - 05:51 PM
I can't see the video, it's marked as private.
If you make the video public then I will take a look.
#51 mrthumb
mrthumb
  • 144 posts
Posted 11 August 2012 - 06:01 PM
ah try again now
#52 Rhys
Rhys
  • 898 posts
Posted 11 August 2012 - 09:16 PM
Yeah that's pretty bad, it's hard to see what's moving. Is it the flange on the disk?
#53 mrthumb
mrthumb
  • 144 posts
Posted 11 August 2012 - 10:12 PM
yea exactley that.
#54 Rhys
Rhys
  • 898 posts
Posted 12 August 2012 - 07:18 AM
Right, it should be very tight to be honest. Is it rocking in the holes or just not tight enough? The CV will make it sit better and tighter do see what happens with one on. It's far from ideal though as it's not the CVs main function.
Edit: Just watched the video again, The play is far too much to be deemed safe, even if the CV can hide it, it will increase the strain on the CV and bearings beyond what they were made for.
Is it the extended holes or the flange not sitting in the disk correctly that's causing it?
Edited by Rhys, 12 August 2012 - 07:23 AM.
#55 mrthumb
mrthumb
  • 144 posts
Posted 12 August 2012 - 09:28 AM
http://www.youtube.c...bed/AtHcocmX6yc
hi its not the extended holes its on there tight and fitting flush. i noticed when i had them done they seems to have more play than i would of thaught they would of had.
#56 Kam
Kam
    Straight to the Point
  • 4,144 posts
  • Local Club: 16vMini club
Posted 13 August 2012 - 08:16 PM
You need to get a driveshaft end in there and torque up the main hub nut, then see where you stand as you can't really go on much at the moment as nothings clamped together
Is your driveshaft in pieces? just poke the outer end through and try the hub nut
#57 mrthumb
mrthumb
  • 144 posts
Posted 15 August 2012 - 07:28 AM
my drive shafts are assembeled bit i could put them through.. and see what happens. i think they need to be re pressed in now its that bad.
#58 mrthumb
mrthumb
  • 144 posts
Posted 15 August 2012 - 12:46 PM
I started to tackle the position of the mini pedal box from OPD... the only problem is. there is not enough room for the standard mini accelerator pedal along side it. and i did not want to fork out another 100 or more for the pedal box that does include the extra pedal...
so i had to go about extending the main shaft that the other pedals run along to i had room for another...
Attached File  pedalmods.jpg   76.02K   23 downloads
just see how it would work.
first i had to extend the shaft that runs through the pedal box... so i machined up a piece and a another section that slides over it..
Attached File  pedalmods1.jpg   52.44K   21 downloadsAttached File  pedalmods2.jpg   42.91K   20 downloadsAttached File  pedalmods3.jpg   41.06K   20 downloadsAttached File  pedalmods4.jpg   40.7K   19 downloads
just looking how it will go on..
Attached File  pedalmods6.jpg   70.48K   24 downloads
Attached File  pedalmods7.jpg   54.86K   20 downloads
time to extend the pedal...
Attached File  pedalmods8.jpg   53.75K   20 downloadsAttached File  pedalmods9.jpg   42.23K   21 downloads
and fitted...Attached File  pedalbox10.jpg   88.03K   29 downloads
#59 mrthumb
mrthumb
  • 144 posts
Posted 15 August 2012 - 12:49 PM
next thing i had to do is cut down the shaft on the steering rack as the wheel was in my face. it sticks out more now because the steering racks new position requires a new knucke joint that brings it forward 60-70mm from its original position.. heres a few pics of what i started...Attached File  steeringcollummod2.jpg   59.18K   27 downloadsAttached File  steeringcollummods3.jpg   57.16K   25 downloads
more to come later on that one, at home with quite a bad back. wish i could get on with somthing !
EDIT!
What it looks like finished. i did drill out and press fit it and weld it. so no ayrton senna antics hopefully!Attached File  steeringrack.jpg   55.87K   18 downloads
Edited by mrthumb, 15 September 2012 - 07:20 PM.
#60 Rhys
Rhys
  • 898 posts
Posted 15 August 2012 - 02:59 PM
Wow, you're welcome here whenever you like with welding skills like that. The fabrication is amazing, you must have a lot of confidence! Keep it up.
