most of the seals have been fully welded in the past which should also help somewhat.
New Build, All The Gear No Idea.
#31
Posted 30 July 2012 - 08:32 PM
#32
Posted 30 July 2012 - 08:43 PM
its unpleasant, hot and dirty work. but sombodys gotta do it :)
there was a few patches of rust holes and filler which i filled in properpley with METAL
Edited by mrthumb, 30 July 2012 - 08:45 PM.
#33
Posted 30 July 2012 - 08:45 PM
ready to be fillered now...
Posted 30 July 2012 - 08:52 PM
Then a coat of stone chip
then a coat of dinitrol wax....
should keep the orange demon at bay.
Edited by mrthumb, 30 July 2012 - 08:55 PM.
#35
Posted 30 July 2012 - 09:04 PM
I welded the steering collum adapter on today...
Now, I know some of you will frown on it not being pinned. but i did chamfer the metal edges in the lathe before i began. I also done 4 runs of tig welding. I tig weld items most days and im confident this will stand up to a lifetime of abuse. I recon you would need tonnes of sheering torque to break this :)
Posted 04 August 2012 - 12:03 PM
I reconditioned, painted and put new brake hoses on the rear subframe i also punched out the old 5/16th UNF studs and welded in some nice new ones so all the bolts and nuts do up and undo perfectley. Everything was assembeled with copper grease so that 10 years from now it will come un done like the day it was put on.
i have hit a snag though. the PCD of the new hubs i got from geoff are 95mm. and my wheels and rear subframe hubs are 100.. what are my options other than getting 2 different wheel sizes?
#37
Posted 05 August 2012 - 04:25 PM
#38
Posted 05 August 2012 - 06:04 PM
Type: MINILIGHT
Colour: SILVER HI-LITE
Size: 5.5 x 13
PCD: 4-101.6
Offset: ET 25
Fitment: MINI-MG MIDGET
Body Mods req: NO
http://www.midlandwh...---4x95.25.html
Type: MINILIGHT
Size: 5 x 13
PCD: 4-95.25
Offset: ET 20
Fitment: TRIUMPH
Body Mods req: NO
http://www.midlandwh...---4x101.6.html
the only thing i can spot is the ET offset...
being 5mm difference... what is this? and what difference will it make if any? thanks.
I also ran the fuel lines today...
Posted 05 August 2012 - 07:02 PM
Your rear subframe? Is it treated? mine is soaked in waxoyl...
#40
Posted 05 August 2012 - 07:58 PM
#41
Posted 05 August 2012 - 08:01 PM
#42
Posted 05 August 2012 - 08:06 PM
http://www.ebay.co.u...984.m1439.l2649
I got 3 meters and it worked out to be about the right length with a bit to spare.
8mm ID for the main line, and 6mm ID for the return.
#43
Posted 05 August 2012 - 08:45 PM
#44
Posted 10 August 2012 - 07:29 PM
http://www.mikesatur..._5.html#aAW3902 Wheel Hub Adapters
and has it turns out they are not really compatable without alot of modification. they also alter the offset which is unfaverable to handeling with my alloys.. 3x7 et 7 minilites...
So instead of wasting them, I decided to use them as a jig or template to drill the holes in a new position.
I layed the PCD adapter with the new holes in the correct position onto the hub and drill through and opened up the holes. im picking up some new studs tomorrow so i should be rolling by the time the weekends finished fingers crossed.
Edited by mrthumb, 10 August 2012 - 07:29 PM.
#45
Posted 10 August 2012 - 07:55 PM
