Fia Battery Kill Switch
3 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 30 March 2012 - 10:28 PM
please can you tell me what colour wire the from the key to the coil is
cheers
brad.
#2 Cooperman
  • 23,278 posts
Posted 30 March 2012 - 11:07 PM
Check with the circuit diagram, but I'm sure it's white.
However, I've twice had a problem with the ignition circuit through these FIA Master Switches failing which cuts the engine. To overcome this I have fitted an 'ignition by-pass' circuit with a small rotary switch. This can be used in an emergency if the FIA ign. master fails during a special stage or test.
#3 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 30 March 2012 - 11:08 PM
okidoke pal cheers
brad.
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 01 April 2012 - 11:50 AM
just looked in a Manuel and it is the white wire but how many amps are going through this wire as am going to replace it
Edited by brad-the-bear, 01 April 2012 - 11:50 AM.
