Gasless Mig Welders? Any Good Or A Bit Crud?
17 replies to this topic
#1 rosstolley
rosstolley
  • 111 posts
Posted 29 March 2012 - 07:21 PM
Any views on the above?
I'm after something small and good for a beginner.
Cheers,
#2 minibarnerz
minibarnerz
  • 479 posts
  • Local Club: torbay mc, somerset rusteez
Posted 29 March 2012 - 07:23 PM
I used one, not great, but very useable.
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 29 March 2012 - 07:31 PM
naff, especially for a beginner.
#4 charie t
charie t
  • 3,153 posts
Get gas then
#5 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 29 March 2012 - 07:34 PM
Everyone seems to say gas all the way but I use a gas less one and get on just fine with it
#6 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 29 March 2012 - 07:36 PM
Gasless welders are enough to put anyone off welding for life!
Gas migs are cheap enough these days, and will give much better/cleaner welds.
#7 stretters
stretters
  • 71 posts
  • Local Club: Ipswich MOC, AMC, CMC, MCR.
Posted 29 March 2012 - 07:38 PM
I used a gasless on my old mini's drivers side floor pan, cost alot of money on wire and time to get it right and look good.
Then I got given a Clarke gas welder and the passenger side floor pan was a breeze, quick and easy with a lot less to grind back.
The initial set up was ok with the small gas bottles, but I have since brought a big bottle regulator and purchased a converted fire extinguisher from my local shop.
So much cheaper to run now and good results every time! Only a tenner to swap bottles and it's 4 foot high!
#8 newnham500
newnham500
  • 221 posts
Posted 29 March 2012 - 07:39 PM
I've been told they spray excess all over the place, but the way I see it. Your gonna be grinding the welds down flat anyway, so if it saves money.
#9 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 29 March 2012 - 07:43 PM
The weld will be half as good AND you will have to spend 10 times longer grinding the weld down.
personally for me, I'd rather pay a bit more, and get the job done MUCH quicker, stronger, and make a much more satisfying job.
#10 Tupers
Tupers
  • 4,143 posts
Gasless is great for industrial work and ship building where lugging bottles around isn't viable but for vehicle restoration it's just not the way to go.
#11 Tupers
Tupers
  • 4,143 posts
Posted 29 March 2012 - 07:45 PM
Just another note, if you have to grind a weld down for it to look good (gas or gasless) it was never a good weld in the first place. :shy:
#12 rosstolley
rosstolley
  • 111 posts
Posted 29 March 2012 - 07:51 PM
Looking like i'll be putting my money on the gas then :proud:
#13 pump
pump
  • 52 posts
Posted 29 March 2012 - 07:59 PM
Was just going to post a question on this, was about to buy a gas less one before i seen this thread. Looks like gas so.
#14 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 March 2012 - 08:19 PM
Now it's my turn to muddy the waters.
Consider a scratch- or lift-start inverter TIG unit. It will cost a bit more than some MIG welders but in the end you will have almost no grinding to do... if any at all. The downside is that it is slower than MIG and you will therefore probably go through more shielding gas. For panel work even the smallest TIGs will work.
#15 Tupers
Tupers
  • 4,143 posts
Posted 29 March 2012 - 08:27 PM
TIGs are amazing for fine panel work but personally I would only go down that route if you've got the time and money to go on a decent body work oriented TIG welding course. There's a lot more to TIG welding than there is to MIG so although the end result is better it takes a lot longer to lean and might not be worth it for a one off project.
