Hi there,
I am having trouble loacating the Idle Control Valve. If anybody has a picture of it or even a diagram I would be very grateful :)
Many Thanks,
Chris.
Idle Control Valve - Where Is It!? Urgent Help Needed Please!
Chris Harper Cooper
, Mar 28 2012 01:29 PM
3 replies to this topic
Posted 28 March 2012 - 01:29 PM
Posted 28 March 2012 - 01:46 PM
http://www.minispare...id=33547&title=
http://www.minispare...id=42331&title=
I have some 2nd hand ones in stock
Posted 28 March 2012 - 01:51 PM
I have found it now but thank you very much for your quick reply! I disconnected my battery and reconnected it with the Idle Control Valve disconnected. I kept the engine revving for around 3 minutes and then reconnected the ICV whilst the engine was still running. The car did not seem to cut out when I let off the throttle which I thought was strange. I am still having the same problem, as I will now not rev above 2k revs without coughing and spluttering, even backfiring! What do you think this may be? Do you think I would need to replace the ICV, if so, how much are you willing to sell one for?
Many Thanks,
Chris.
Many Thanks,
Chris.
Posted 30 March 2012 - 09:01 AM
That doesn't sound like the idle control valve (should have no effect on anything other than the idle speed/ stability).
Would be guessing, but when my crank sensor went it caused the same sort of issues. Try wiggling the wire to the crank sensor and see if it goes away?
