Replacing Drive Shaft Seal?
Ryang556
, Mar 26 2012 04:54 PM
7 replies to this topic
Posted 26 March 2012 - 04:54 PM
We are pretty sure that it is leaking from the passenger side drive shaft, and I mean a nice fresh small puddle every time it stops so it is leaking a fair bit, what're these like to change, engine out job?
Posted 26 March 2012 - 04:57 PM
just driveshaft out job....
Posted 26 March 2012 - 05:01 PM
So not too much work involved..?
Posted 26 March 2012 - 05:19 PM
i did this on the drivers side all i did was undo bottom nuts onteh hub and take the shock off and pulled out the drive shaft from the cup then removeed the cup and the seal and the replace it all was nice and easy
Posted 26 March 2012 - 06:38 PM
Doesn't sound too difficult then, will probably sort it out sometime this week as it's leaking like a sieve
Posted 26 March 2012 - 07:58 PM
yea mine was as well just make sure you keep it toped up
Posted 26 March 2012 - 08:05 PM
Don't forget to drain the oil first!
Posted 26 March 2012 - 08:07 PM
I've got to do a RH one tomorrow morning.
Sequence is:
Drain the oil
Undo top & bottom swivel pins and split them supporting the hub on a box
Break the pot joint out of the output shaft using two large screwdrivers or a wedge (oe even the proper Rover tool)
With the shaft clear undo the 5 off 5/16" UNC (1/2" AF) bolts and remove the cover plate.
Replace the oil seal and fit a new gasket.
Replacement is reverse of above.
I always use a bit of Blue Hylomar on those cover plates, but it's up to you.
On the LH side make sure the shims go back in or the diff bearings will not have the correct pre-load
Sequence is:
Drain the oil
