What Happens When A Ball Joint Snaps :(
45 replies to this topic
#16 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 24 March 2012 - 04:45 PM
Yep im so lucky to be here now the pin didn't actually snap it pulled out of the socket which then caused the other pull joint to snap the hub so had to replace hub drive shaft bearing and ball joints been a long day and it pushed the a panel back into the door I've sort of straightened it for now :)
#17 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 March 2012 - 05:26 PM
everyones nightmare! Is there a guide to checking our ball joints?
#18 mab01uk
mab01uk
  • 12,370 posts
Posted 24 March 2012 - 05:56 PM
Can you post some close up pictures of the damaged parts..........it would be useful if anyone who suffers a balljoint failure took photos of the offending parts and posted them on TMF so we can try to work out what /how failure has occured in each case, also the source/make of balljoint if known.
#19 PAWL3Y
PAWL3Y
  • 84 posts
Posted 24 March 2012 - 09:38 PM
i second this, also are there any signs of ball joints failing?
#20 purple_fly06
purple_fly06
  • 594 posts
  • Local Club: The Mini Foresters
Posted 24 March 2012 - 09:55 PM
got some serious negative camber going on there
#21 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 24 March 2012 - 11:47 PM
Here you go
#22 Boycie
Boycie
  • 1,978 posts
Posted 25 March 2012 - 08:39 AM
So the pin pulled out of the cup Danny and then the lower joint sheared when the hub swung round?
The only thing I can think has happened to allow the pin to pull through is that the car is too low at the front and the pin and cup have been wearing sideways-ey? (technical term :D)
Check the other side ASAP!
#23 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 25 March 2012 - 04:42 PM
Yep exactly what happened and the mini is running 2 inch off the front bump stops so its not really really low i realised Wednesday they where knocking so said to myself job for Saturday and bang Friday night they give up :(
#24 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 25 March 2012 - 04:46 PM
Did you replace them last?
#25 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 25 March 2012 - 04:48 PM
Did the police mention that you have your front numberplate in a stupid place?
#26 abe46
abe46
  • 431 posts
  • Local Club: South Devon Mini Club
Posted 25 March 2012 - 04:49 PM
I wonder if the same thing happened to this chap.. ;D
#27 Jeffreypang911
Jeffreypang911
  • 237 posts
Posted 25 March 2012 - 05:14 PM
DId you damage the fender at all? good thing youre ok.
#28 Boycie
Boycie
  • 1,978 posts
Posted 25 March 2012 - 05:36 PM
2 inches off the bump should have been fine Danny.. looks like it has taken a bit of abuse in the past though :(
If only it had lasted out another day... :cry:
#29 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 25 March 2012 - 11:56 PM
Ya if only one more day and he did say something about the regarding plate he said that where his was when he owned a mini and yep a panel is bent back to the door my girlfriend coundnt open the door and the wings also dented the arch it self other.fine gonna straighten what i can and sticker bomb both a panels.for.now
Danny
#30 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 26 March 2012 - 09:37 AM
And here's the damage I've knocked the a.panel.out of the door for now
Danny
