Bad Damage Need Help Please!
#31
Posted 20 March 2012 - 05:59 PM
#32
Posted 20 March 2012 - 06:22 PM
#33
Posted 20 March 2012 - 06:23 PM
#34
Posted 20 March 2012 - 06:25 PM
#35
Posted 20 March 2012 - 06:26 PM
and i have bent them much worse than that and not broken a lamp
#36
Posted 20 March 2012 - 06:41 PM
#37
Posted 20 March 2012 - 09:14 PM
#38
Posted 20 March 2012 - 09:41 PM
#39
Posted 20 March 2012 - 11:29 PM
Hang on a minute boys(and ladies), the car jumped forward, up and over the stops. off the ramp, so how manged to gain traction again to pin a guy against the wall, all on the starter motor. hmmm. if you ask me, with those pictures. they took your car out after doing the work to "See what these minis really go like", lost control hit a bollard and maybe the curb and tried to blame it on a work shop accident.
behind the ram is about a meter meter and a half space, the mini would not have come off the ramp and got enough traction to hit the wall, unless it came off that ramp at a fair speed. at that speed the boy would be critially ill, not pinned. plus the impact would be from below, those picture show an impact from the front. we have all moved a car on a starter motor, it jumps about a foot. the only way that could of overridden the stops and hit the wall, assuming the wheels hit the floor after and got traction, is if the driver had the ignition on for a good 5/10 seconds.
im sorry they are lying, and finally if the boy was between the car and wall. either he is made of steel or they are lying, how would his body dent the front. i would expect to see damage on the bottom where the front hit the floor, and not on the front cause his body custioned the blow. instead its all frontal and none under.
tread careful, somthing doesnt add up.
Completely agree, there is no way a starter motor on the mini could pop that over those bumps, even my dads 2.2L avensis couldnt go that far,
#40
Posted 21 March 2012 - 12:19 AM
Edited by 850mini, 21 March 2012 - 12:25 AM.
#41
Posted 21 March 2012 - 08:15 AM
#42
Posted 21 March 2012 - 04:58 PM
#43
Posted 21 March 2012 - 05:25 PM
#44
Posted 21 March 2012 - 05:45 PM
#45
Posted 21 March 2012 - 05:56 PM
