Engine Strip Down, Are These Pistons Useable
Posted 17 March 2012 - 05:57 PM
no damage to any parts around the rings but where it was burning through the piston rings it has left some marks.
the strange thing is there are no marks on the bore.
have a look and please let me know what you think. always good to have a second opinion.
piston 1
Piston 3
Piston 4 Has damage on both sides.
thanks
Posted 17 March 2012 - 06:00 PM
Posted 17 March 2012 - 06:01 PM
Posted 17 March 2012 - 06:03 PM
Was they tight in the bores at all? Is it a previously re build engine? Its either picked up some foreign debris, or bore tollerences where to tight?
Strange there isn't any marking in the bore. Any marks at the bottom of the bore?
Edited by Pauly, 17 March 2012 - 06:04 PM.
Posted 17 March 2012 - 06:06 PM
Posted 17 March 2012 - 06:15 PM
Was a tight fitwhen fitted.
When I measured the bores it was under the standard size by 0.020"
Posted 17 March 2012 - 06:20 PM
Posted 17 March 2012 - 06:21 PM
But its a shame as they looked really good before i took them out.
Posted 17 March 2012 - 06:24 PM
Posted 18 March 2012 - 05:37 PM
this is a A+ engine i took out of my mini that ran good for two years.
looks like the engine has had some work done to it in the past due to the gaskets and new bolts etc.
the top of the cylinders don't look 100% but may clean up with a home hone.
the cam shaft look to be a standard 998 A+ cam shaft
the pistons look really good.
but i don't recognise them,
the crank has these id numbers on them, is there anything special about that.
ok and my last question will be would there be a problem putting a A+ crank pistons, cam etc on to a pre 72 A series block.
as all the interals are exellent on my A+
but the block is much better on the old A series.
thanks steve
Edited by booton, 18 March 2012 - 05:40 PM.
Posted 18 March 2012 - 06:40 PM
Posted 18 March 2012 - 06:51 PM
i've not cleaned them up at all and they came out easily enough were not seized.
would there be a problem with these pistons once they have been cleaned up.
it is a std bore on both pistons and bores.
Posted 18 March 2012 - 07:51 PM
are these standard pistons std ones. as all the pistons i have seen have circlips to hold the pin in the piston.
does anyone know where i could find out what the number on the crank means.
thanks
Posted 19 March 2012 - 07:55 AM
Posted 19 March 2012 - 06:29 PM
thanks steve
