Shelf Life Of Unleaded Fuel
Posted 14 March 2012 - 11:27 PM
Interesting write up on shelf life of modern petrol here:
"The gradual elimination of Sulphur from fuel (not well publicised) has resulted in a lower shelf life for unleaded fuel. Oil companies surveyed estimated that a half full tank of unleaded could be unusable in as little as 2 months. Sulphur used to be added as a preservative to slow down algae growth in the fuel. Without it, the algae grow and the fuel quality deteriorates. How old is the fuel in your tank now?"
So yesterday, I phoned the BP Technical Support Line, and asked about the shelf life of unleaded fuel. “One month” I was told. “After one month in a half full fuel tank (ie: unsealed, plenty of air space) you would notice a drop in power. After three months, the car would be hard to start, would not idle well, and would suffer a significant loss of power. By this time, much of the high volatility elements in the fuel will have evaporated, leaving the more dense part of the mixture. In addition, the fuel will be oxidising and fungus will be growing. The fuel takes on an orange colour and gets progressively darker as time goes by.”
More:
http://www.spriteparts.com.au/tech/fuel.html
Posted 14 March 2012 - 11:41 PM
Posted 14 March 2012 - 11:51 PM
if you were to buy a bag of sulphur could you just add a wee bit to the fuel if you dont use it that often to help preserve it?
Posted 15 March 2012 - 12:04 AM
Posted 15 March 2012 - 12:10 AM
Posted 15 March 2012 - 12:27 AM
Posted 15 March 2012 - 07:22 PM
POR15 Fuel Preservative & Stabilizer
http://www.frost.co....er-us-pint.html
Edited by mab01uk, 15 March 2012 - 07:23 PM.
Posted 15 March 2012 - 08:28 PM
Posted 15 March 2012 - 10:51 PM
Personally I think its all just mince. I have shell unleaded fuel in my Marina and its been sat for 3 years and still STARTS!
It is not 'mince' I am not imagining this...........it happens to mine and others I know with cars and little used classic motor bikes have the same problem, 3 years ago your fuel is unlikely to be the same make up as that on sale now maybe. The more sealed the fuel system is from the air the better, it lasts alot longer in a fuel injected car for this reason.
Quote:
"The gradual elimination of Sulphur from fuel (not well publicised) has resulted in a lower shelf life for unleaded fuel. Oil companies surveyed estimated that a half full tank of unleaded could be unusable in as little as 2 months. Sulphur used to be added as a preservative to slow down algae growth in the fuel. Without it, the algae grow and the fuel quality deteriorates."
Edited by mab01uk, 15 March 2012 - 10:55 PM.
Posted 16 March 2012 - 03:22 AM
To be honest i think this is mince also.
Even if the car/bike will not start all you have to do is drain it out from the float bowl and it will go on the stuff in the tank (old cars and bikes) as the stuff in the float bowl goes of alot quicker.
I put old petrol in my mini and morris minor on a regular basis because i tend to get hold of a lot of it through my dad's motorbike shop where the customer wants new fuel.
Reality is the bike starts up on the old stuff 9 times out of 10. I have also never had a problem with it in my mini
Jesus
Posted 16 March 2012 - 06:13 AM
Posted 16 March 2012 - 09:35 AM
You have to use a bit of common sense here.....obviously the useable life of any fuel depends on how it is stored....temperature, exposure to sunlight, water contamination, what type of storage tanks are used, contamination with other fuels (they all go down the same pipeline!!), and gets mixed with various other fuel in storage tanks even before it gets to you etc etc etc
So it is impossible for an oil company to state an exact shelf life but they have to state something so they say 1 month. In fact they also state 1 month for biodiesel which degrades a lot faster than gasoline, so that tells you something straight away!!
Modern vehicles have much better fueling systems which are not so exposed to the environment so you can expect the fuel to last much longer than in an older vehicle....
Posted 16 March 2012 - 01:48 PM
Posted 17 March 2012 - 06:35 PM
Posted 17 March 2012 - 07:24 PM
I work for a company that manufactures aviation fuel storage facilities and we store upto 18,000 litres of a certain type of aviation fuel (Jet1A).
So long as we keep it in an airtight environment it will keep for quite a while without degrading,but there are additives that we can introduce to most fuels that keep it fresh and free from bacterial growth which only causes problems when a certain amount of water/condensation is present in the storage facility.
As we all know,all forms of life need water to survive and the bacteria live where the fuel lays ontop of the water. Anyway less of work, just mix and drive.
