Any Electrians - Question About Immersion Heater
9 replies to this topic
#1 LukeH
LukeH
  • 1,004 posts
Posted 13 March 2012 - 11:22 AM
Hi,
I'm hoping someone can help me regarding the use of an immersion heater.
I want to know of it is safe to put a 13amp plug on the immersion heater and plug it into a digital timer? (not a specific immersion timer)
My immersion is rated at 3kw, which should draw 12.5amps (3000 / 240volts = 12.5). My digital timer is rated at 13amps at a max load of 3120watts.
The plug socket is on its own feed from the fuse board which is rated at 15amps.
My main concern is whether it's safe to use a 13amp plug and timer or should I purchase a hardwired immersion timer?
Thanks in advance.
Luke
#2 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 13 March 2012 - 12:11 PM
Hi,
Its more usual (and safer) to hard wire your immersion heater through a 20A fused outlet. Doing what you're proposing is not that safe as you are running everything at its max current limit with no margin.
In my experience, running anything that draws 3kW on a 13A plug/socket outlet is ok whist all is new and tight. Sometimes cables can come loose in the screwed terminals due to the 50Hz mains which can in extreme instances can vibrate screws loose.
This causes a heat build up because the connection now has a higher resistance but is still trying to pass 3kW of power.
I've watched a fuse box at work catch fire due to a loose terminal on a circuit that was passing current near to its 100A limit....scarey!!
Hope this helps.
Steve.
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 March 2012 - 05:20 PM
^^that^^
you running very close to the 13a plugs limits and for the amount of time a immersion heater is on for things could start getting very hot
i would stick with the hard wiring and fit a hard wired timed
on a side note have you heard about part P of the building regs ?
#4 Gaffer
Gaffer
    Previously known as j519ldv. King of the spam costume!
  • 457 posts
  • Local Club: Crash Barrier Minis
Posted 13 March 2012 - 06:43 PM
Part p only applies if you use the new grey cable ;0)
Im agreeing with the rest, for the effort thats involved its just as easy to hardwire it in
#5 LukeH
LukeH
  • 1,004 posts
Posted 13 March 2012 - 07:13 PM
Thanks for the replies. Yes I am aware of part p building regs.
The main issue is that I live in a rented house with an oil boiler. I would like to make use of the immersion in attempt to reduce the amount of oil I buy.
The immersion is currently hard wired into a switch, no fuse, on its own breaker at the fuse board.
I think I'll do things the right way and get a hard wired immersion timer.
Cheers, Luke
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 March 2012 - 08:42 PM
LMAO can you post a link to back up this statement
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 March 2012 - 08:45 PM
so your ok to test the modified circuit and issue a certificate + don't forget to notify building control of this work if the immersion is in the bathroom or kitchen
#8 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 14 March 2012 - 01:41 PM
Perfect, I won't need to do mine then! Oh dear...
#9 Gaffer
Gaffer
  • 457 posts
Posted 14 March 2012 - 07:04 PM
http://www.diydata.c...ctric_cable.php
cables turned grey in 2004 before the introduction of part p in2005.
Circuits in grey cable obviously would have been installed after part p and would therefore need to be certified by a competent qualified person (well new circuits etc).
On a serious note though, its not recommended and part p is there to protect and comply with current legislation so its best to do it properly
#10 blacktulip
blacktulip
  • 6,224 posts
Posted 15 March 2012 - 12:47 AM
from what i hear at work its best to hardwire it.
