Bench Mounted Engine Stand
4 replies to this topic
#1 JonBetts
JonBetts
  • 298 posts
Posted 11 March 2012 - 09:56 PM
Bench mounted engine stand for the A Series engine that allows you to roate and lock the engine block in any position, ideal for building up the block, crank, pistons etc before it is fitted onto the gearbox. Fits to the alternator and oil filter housing fixing points so a strong location. £25 with free postage for short period. Message me on here or email [email protected] for more info
2012-02-1522.52.10 by JBFabrication, on Flickr
2012-02-1413.23.24 by JBFabrication, on Flickr
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 March 2012 - 10:02 PM
does it come with bolts for engine mounting? and bolts for bench mounting?
#3 JonBetts
JonBetts
  • 298 posts
Posted 11 March 2012 - 10:06 PM
Depends how thick your bench is lol can probably sort the bolts out to fix to engine but dont normally supply them as owner normally has these if they have stripped engine down.
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 March 2012 - 10:11 PM
yeah makes sense about the bench. Im thinking of my workshop and trying to find the bolts, if it came with bolts i could store it in a tupparware box somewhere.
#5 JonBetts
JonBetts
  • 298 posts
Posted 11 March 2012 - 10:15 PM
As long as your bench isnt more than around 65mm thick then I should be able to help you out ;-)
